5 Replies Latest reply on Dec 28, 2009 7:37 AM by Faser
    How to disable auto sorting in a datagrid
    Faser
      Every time a new item is added to the data provider or some properties are changed, the rows in the datagrid are automatically sorted using the new values.
      How can I prevent this behavior? I tried using collection.disableAutoUpdate(), but in this way the values shown in the datagrid are not updated too.
      I want the datagrid is sorted only when the user click on the columns header, not when the data change.
        • 1. Re: How to disable auto sorting in a datagrid
          Francisc Level 3
          Try sortableColumns=false (as3) or sortableColumns ="false" (mxml) for the DataGrid Control.
          • 2. Re: How to disable auto sorting in a datagrid
            Faser Level 1
            Before updating the values I empty out the sort.fields array and I avoid
            to refresh the collection binded to the datagrid.
            collection.sort.fields = ;
            //collection.refresh();}
            It seems to work.
            • 3. Re: How to disable auto sorting in a datagrid
              Faser Level 1
              No, sorry I was wrong. It doesn't work and sortableColumns=false prevent the user to click the column header, but when some items in dataprovider change the row in the datagrid are reordered.
              • 4. Re: How to disable auto sorting in a datagrid
                Flex harUI Adobe Employee
                dataProvider = dataProvider.toArray() will lock the current sort order.
                Alex Harui
                Flex SDK Developer
                Adobe Systems Inc.
                Blog: http://blogs.adobe.com/aharui
                • 5. Re: How to disable auto sorting in a datagrid
                  Faser Level 1
                  Thank you Alex, but in this way the datagrid is no more updated when I  change the collection.
                  dataGrid.dataProvider = myCollection.toArray();
                  So, the only way I found to prevent auto-sorting is to add a a new  property to the objects in the collection. This field store the original  rowIndex and I set the datagrid to sort using this new field.
                  public function sortByItemIndex():void{
                              var itemIndexSortField:SortField = new SortField();
                                  itemIndexSortField.name = "itemIndex";
                                  itemIndexSortField.numeric = true;
                              var mySort:Sort = new Sort();
                                  mySort.fields = [itemIndexSortField];
                                  collection.sort = mySort;
                  public function setItemIndex():void {
                              for each(var order:Order in collection){
                                  order.itemIndex = collection.getItemIndex(order);
