4 Replies Latest reply on Feb 25, 2010 2:07 AM by frszilinski
    Calculate Font/Text Metrics
    frszilinski Level 1
      Hi all,
      I need to calculate the width and height of a certain font with a specific text.
      Short Example (values are fictitiouse):
      Font="Arial" FontSize="10"
      Text="acs" => width=30 & height=10
      Text="acd" => width=30 & height=14
      Text="acW" => width=38 & height=15
      Text="gcW" => width=38 & height=22
      Do somebody of you know a way how to do that? Fonts can't be embedded because list of fonts need to be device fonts...
      Hope somebody can help me!
        • 2. Re: Calculate Font/Text Metrics
          frszilinski Level 1
          I already found this, thanks.
          But how can I get the exact height of the text with a specific font?
          "w"  =>  height=20px
          "W"  =>  height=28px
          "qW"  => height=34px
          See, I get the height and descent, but there is no way to get the high from the second red line to the first (so the additional high of the W compared to x)
          Does somebody know how to calculate or get the exact measurement? Said I like to draw a rectangle around the text with no spaces...
          Thank you!!!
          • 3. Re: Calculate Font/Text Metrics
            frszilinski Level 1
            Bumb and here is a sample code so you can try what I did so far
            private function testToMeassureText(text:String):void {
                 var font:String = "Times New Roman";
                 var size:Number = 10;
                 var myTextField:TextField = new TextField();
                 myTextField.x = 0;
                 myTextField.y = 0;
                 myTextField.background = false;
                 myTextField.wordWrap = false;
                 myTextField.autoSize = TextFieldAutoSize.LEFT;
                 myTextField.text = text;
                 var newFormat:TextFormat = new TextFormat();
                 newFormat.size = size;
                 newFormat.font = font;
                 newFormat.italic = false;
                 newFormat.bold = false;
                 myTextField.setTextFormat(newFormat);
                 var metrics1:TextLineMetrics = myTextField.getLineMetrics(0);
                 trace("------------------------------------------------------");
                 trace("Metrics ascent is: " + metrics1.ascent.toString());
                 trace("Metrics descent is: " + metrics1.descent.toString());
                 trace("Metrics height is: " + metrics1.height.toString());
                 trace("Metrics width is: " + metrics1.width.toString());
            Also tried:
            var bound:Rectangle = myTextField.getCharBoundaries(0);
            trace("Char width is: " + bound.width);
            trace("Char height is: " + bound.height);
            Same Problem, the height always the same, doesn't matter if it is iE. an "a" "A" or "g"
            Now I know, I am searching for the x-height of a font but I could not find a solution!
            Any Ideas?
            Message was edited by: frankhoff
            • 4. Re: Calculate Font/Text Metrics
              frszilinski Level 1
              Everybody who is interested in the solution, check out my blog (german but code should work in other languages too:)
              http://www.esentri.com/blog/2010/02/flex-fontmetrics-und-exakte-berechnung-der-schrift-bre ite-und-hohe/
