3 Replies Latest reply on Jan 6, 2010 3:07 AM by macrofireball
    Audio sounds tinny
    johnquad1111
      Using Captivate 4 with standard default settings for everything. Audio sounds sounds fine in preview mode but sounds tinny when published to swf. Installed latest patch to fix audio problem but same problem remains. Are my settings wrong? What should I do?
        • 1. Re: Audio sounds tinny
          macrofireball Level 3
          Hi there,
          Try checking to see what the Audio quality is set to in the Project Information section of the Publish dialog box (File > Publish). By default this should be to set to 96 kbps - Near CD Quality, as shown in the screen shot I have included below.
          If this doesn't solve the problem, then I would suggest that you export the audio using the steps I have included below and check to see if the audio still sounds tinny when you play it in an audio player such as Windows Media Player.
          Exporting audio
          1. In Edit view choose Audio > Audio Management
          2. Select the entry in the Advanced Audio Management dialog
          3. Press Ctrl + A to select all the other slides
          4. Make sure Include MP3 and WAVE files in export are selected
          5. Click the Export button
          6. In the Browse For Folder dialog select a folder to export the selected audio files to
          7. Click OK.
          8. Click OK again to dismiss the Advanced Audio Management dialog
          HTH
          Best - Mark
          Visit the macrofireball blog
          • 2. Re: Audio sounds tinny
            johnquad1111 Level 1
            Mark,
            Thanks for the help. The default was not 96 kbps and this caused the problem. When I switched it the tinny noise vanished. Thanks again!
            Sincerely,
            John Alli
            Poole & Associates, Inc.
            10820 Guilford Road, Suite 201
            Annapolis Junction, MD 20701
            Phone: (240) 373-3604
            www.pooleinc.com
            • 3. Re: Audio sounds tinny
              Hi John,
              No problem, glad to hear that you have managed to solve this issue.
              Best - Mark
