0 Replies Latest reply on Dec 23, 2009 7:34 AM by Carol L. Frampton
    [svn:fx-trunk] 13194: RichText needs to recompose if the contentHeight isn' t the same as the unscaledHeight since the content height could be an estimated height which doesn 't all the text lines composed yet to back up that height.
    Carol L. Frampton Level 2
      Revision: 13194
      Revision: 13194
      Author:   cframpto@adobe.com
      Date:     2009-12-23 07:34:01 -0800 (Wed, 23 Dec 2009)
      Log Message:
      RichText needs to recompose if the contentHeight isn't the same as the unscaledHeight since the content height could be an estimated height which doesn't all the text lines composed yet to back up that height.
      baselinePosition should always return a non-0 value, even if there are no text lines so that components that use the baseline for positioning, such as ButtonBar, don't jump around when the width of the component is changed.
      QE notes:
      Doc notes:
      Bugs: SDK-24750, SDK-24773
      Reviewer: Gordon
      Tests run: checkintests, cyclone on Label, RichText
      Is noteworthy for integration: no
      Ticket Links:
          http://bugs.adobe.com/jira/browse/non-0
          http://bugs.adobe.com/jira/browse/SDK-24750
          http://bugs.adobe.com/jira/browse/SDK-24773
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Label.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/RichText.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/TextBase.as
