0 Replies Latest reply: Dec 23, 2009 12:17 PM by Darrell Loverin RSS
    [svn:fx-trunk] 13201: Fix RTE when calling PopUpManager.createPopUp() from a module or sub-application.
    Darrell Loverin Adobe Employee
      Revision: 13201
      Revision: 13201
      Author:   dloverin@adobe.com
      Date:     2009-12-23 12:16:41 -0800 (Wed, 23 Dec 2009)
      Log Message:
      This fix adds a moduleFactory parameter to PopUpManager.createPopUp() to allow a module or sub-application to specify the style manager to be used. Modules and sub-applications should always pass a moduleFactory to PopUpManager.createPopUp() or PopUpManager.addPopUp() to ensure the correct style manager is used when looking up styles. Otherwise the parent of the pop up is used to determine the style manager.
      QE notes: Please create a PerModuleStyles test that uses the new parameter to createPopUp().
      Doc notes: None.
      Bugs: SDK-24835.
      Reviewer: Alex
      Tests run: checkintests, Managers/PopUpManager
      Is noteworthy for integration: no
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24835
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/IPopUpManager.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/PopUpManager.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/PopUpManagerImpl.as
