0 Replies Latest reply on Dec 23, 2009 1:11 PM by Carol L. Frampton
    [svn:fx-trunk] 13207: Accepted patch for UITextField textHeight property to work around an underlying bug in the player .
    Carol L. Frampton Level 2
      Revision: 13207
      Revision: 13207
      Author:   cframpto@adobe.com
      Date:     2009-12-23 13:11:43 -0800 (Wed, 23 Dec 2009)
      Log Message:
      Accepted patch for UITextField textHeight property to work around an underlying bug in the player.
      flash.text.TextField does not take into account the leading on the final line of text when measuring itself, yet will scroll if it is not given this extra height. The player has retired this bug.
      Ported componentSmoke test to basicTests.  If this fail it means the player has fixed the bug and we need to remove the workaround.
      QE notes: components/Text/Properties/Text_Properties_tester Checking_Property_textHeight needs to be updated
      Doc notes:
      Bugs: SDK-24461
      Reviewer:
      Tests run: checkintests, mx Label, Panel, TextInput, TextArea and Text
      Is noteworthy for integration: no
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24461
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UITextField.as
          flex/sdk/trunk/frameworks/tests/basicTests/halo/scripts/TextTestScript.mxml
