1 Reply Latest reply on Dec 24, 2009 12:19 AM by Mylenium
    Extremely low quality when media is imported
    Wubblelvr1
      Just what is in the title. I am pretty beginner at Adobe After Effects but am pretty advanced with photoshop if that helps at all. I am using cs4 so please help. The quality is really low when I import the media.So please help
        • 1. Re: Extremely low quality when media is imported
          What media? Please be more specific! For starters, after the import check File --> Interpret Footage --> Main. Most likely everything is correct, though. If footage contains fields, AE only displays the dominant one, effectively giving you half the vertical resolution while you work. this does not affect final output in any way, assuming that you use matching field settings there.... More on that in the help.
          Mylenium
