0 Replies Latest reply on Dec 23, 2009 1:49 PM by Chet Haase
    [svn:fx-trunk] 13208: Dealt with my FIXMEs in the code.
    Chet Haase Level 3
      Revision: 13208
      Revision: 13208
      Author:   chaase@adobe.com
      Date:     2009-12-23 13:49:14 -0800 (Wed, 23 Dec 2009)
      Log Message:
      Dealt with my FIXMEs in the code. Some went away (no longer issues), some became TODOs (still issues, but nothing that we have to solve in this release), a couple were actually resolved in this change (like the bug filed/fixed: 24848).
      QE notes: 10 failures in Mustella of tests that need to be changed. They're excluded for now and QE has local fixes.
      Doc notes: None
      Bugs: SDK-24848
      Reviewer: Jason
      Tests run: checkintests, Mustella (spark/effects, mx/effects)
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24848
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/CompositeEffect.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/Effect.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/EffectTargetFilter.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/PropertyChanges .as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/SequenceInstanc e.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/SliderBase.a s
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/AddAction.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/AnimateTransform.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Move.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Move3D.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/RemoveAction.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Rotate.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Rotate3D.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Scale.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Scale3D.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/animation/Animation.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/animation/MotionPath.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/animation/Timeline.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/supportClasses/AnimateInstance .as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/supportClasses/AnimateTransfor mInstance.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/supportClasses/AnimateTransiti onShaderInstance.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/supportClasses/MoveInstance.as
