0 Replies Latest reply on Dec 23, 2009 3:46 PM by kevinklin
    [svn:fx-3.x] 13209: Adding same fix for SDK-23838 and SDK-24205 to 3. x from trunk.
    kevinklin Adobe Employee
      Revision: 13209
      Revision: 13209
      Author:   klin@adobe.com
      Date:     2009-12-23 15:45:53 -0800 (Wed, 23 Dec 2009)
      Log Message:
      Adding same fix for SDK-23838 and SDK-24205 to 3.x from trunk.
      The dropDown was not receiving changes to styles nor dataproviders. This was a result of not recreating the dropDown each time it was shown. I've changed the default of the flag for destroying the dropDown to be true. I've also modified the code to only not destroy the dropDown when it is showing or being shown. I?\226?\128?\153ve also moved some of the code in the animation handler to check for a null dropDown first before destroying it.
      QE notes: No
      Doc notes: No
      Bugs: SDK-23838, SDK-24205
      Reviewer: Jason
      Tests run: checkintests, ComboBox
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23838
          http://bugs.adobe.com/jira/browse/SDK-24205
      Modified Paths:
          flex/sdk/branches/3.x/frameworks/projects/framework/src/mx/controls/ComboBox.as
