3 Replies Latest reply on Jul 11, 2008 1:02 PM by smiffy47
    SSI or MYSQL
    smiffy47 Level 1
      I run a site for people to access info on various social resources. I have used Server Side Includes to store the small quantites of info on various organisations, and it is displayed fine. However, to check the info remains accurate I have to chase up each organisation every few months, collect any changes and make the alterations to the ssi's.
      I am wondering if by changing to a database-run system I could get the various organisations to input the updated info themselves.
      Would it be very complicated to setup?
      Am I likely to run into endless problems? I have only a very small experience of php/mysql.
      Is there some existing system I can employ so that I don't have to try and re-invent the wheel?
      An example of my site can be seen at
      http://www.hopeless.me.uk/Pages/dayactivities/dayactivities_bx.php
      Steve
        • 1. Re: SSI or MYSQL
          shelleyfish
          Hey, have you thought about using a CMS. I use Expression Engine which is pretty easy to setup and works a treat!
          • 2. Re: SSI or MYSQL
            Level 7
            Starting from ground zero with dynamic coding, databases and application
            building? Yes, most likely, if you are wanting to do a custom application.
            Not if it's done properly, no.
            You could take a look at http://www.content-seed.com - it's pretty simple,
            and might be all you need.
            Murray --- ICQ 71997575
            Adobe Community Expert
            (If you *MUST* email me, don't LAUGH when you do so!)
            http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
            http://www.dwfaq.com - DW FAQs, Tutorials & Resources
            "smiffy47" <webforumsuser@macromedia.com> wrote in message
            news:g56u50$58m$1@forums.macromedia.com...
            >used
            > remains
            > any
            > various
            > experience
            > of php/mysql.
            > Thanks,
            > Steve
            • 3. Re: SSI or MYSQL
              smiffy47 Level 1
              Thanks for the suggestions.
              I've had a quick look at Contentseed but I dont think it will do. I realise that I had not made it clear to you that the ssi's that show up on the webpage I gave also appear on other webpages. Some are used many times, and so to edit any content on one page will not do. I need something where one change will change the content site-wide, which is why I thought a database system might be needed.
              Any other thoughts?
