0 Replies Latest reply on Jun 14, 2008 2:35 PM by flatpickinJohn
    Accordion/Repeater/UI Form
    flatpickinJohn
      I'm using an xml object as a repeater dataprovider for an accordion that generates multiple ui forms in the accordion based on the number of children in the xml object. works great except I can't modify the data during run time. I can create one form in my mxml accordion without a repeater and get and set data back to the data base but I need to handle multiple forms. Any ideas...this is driving me nuts.
      If you look at my code I'm only populating on change for the address_1 field which doesn't help.
      I did find this: Run-time changes to an array used as a data provider are not reflected in the Repeater component. Use a collection if you need to allow run-time modification.
      Does this mean any run time changes or just to arrays? remember, I'm not using an array as a dataprovider, i'm using an xml object.
      John
