3 Replies Latest reply on Dec 28, 2009 6:20 PM by Egyptian1993
    SWF (Flex created) In JSP
    vksvicky Level 1
      I created a Flex project, now I want to import it into the JSP, so I have just taken the 'noscript' section and have added to my jsp.
      But the porblem is that the swf file does not play, any help?
      Here is the piece of code
      <noscript>
             <object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000"
                     id="TeamStructure" width="100%" height="100%"
                     codebase="http://fpdownload.macromedia.com/get/flashplayer/current/swflash.cab">
                     <param name="movie" value="TeamStructure.swf" />
                     <param name="quality" value="high" />
                     <param name="bgcolor" value="#869ca7" />
                     <param name="allowScriptAccess" value="sameDomain" />
                     <embed src="TeamStructure.swf" quality="high" bgcolor="#869ca7"
                          width="100%" height="100%" name="TeamStructure" align="middle"
                          play="true"
                          loop="false"
                          quality="high"
                          allowScriptAccess="sameDomain"
                          type="application/x-shockwave-flash"
                          pluginspage="http://www.adobe.com/go/getflashplayer">
                     </embed>
           </object>
      </noscript>
      All the paths and other stuff have been validated!!
        • 1. Re: SWF (Flex created) In JSP
          saisri2k2 Level 4
          I think if you rename the originl HTML to .jsp file it should be enough.
          or
          The following are all required i guess.
          <body scroll="no">
          <script language="JavaScript" type="text/javascript">
          // Version check for the Flash Player that has the ability to start Player Product Install (6.0r65)
          var hasProductInstall = DetectFlashVer(6, 0, 65);
          // Version check based upon the values defined in globals
          var hasRequestedVersion = DetectFlashVer(requiredMajorVersion, requiredMinorVersion, requiredRevision);
          if ( hasProductInstall && !hasRequestedVersion ) {
          // DO NOT MODIFY THE FOLLOWING FOUR LINES
          // Location visited after installation is complete if installation is required
          var MMPlayerType = (isIE == true) ? "ActiveX" : "PlugIn";
          var MMredirectURL = window.location;
              document.title = document.title.slice(0, 47) + " - Flash Player Installation";
              var MMdoctitle = document.title;
          AC_FL_RunContent(
          "src", "playerProductInstall",
          "FlashVars", "MMredirectURL="+MMredirectURL+'&MMplayerType='+MMPlayerType+'&MMdoctitle='+MMdoctitle+"" ,
          "width", "100%",
          "height", "100%",
          "align", "middle",
          "id", "Hygeia",
          "quality", "high",
          "bgcolor", "#869ca7",
          "name", "Hygeia",
          "allowScriptAccess","sameDomain",
          "type", "application/x-shockwave-flash",
          "pluginspage", "http://www.adobe.com/go/getflashplayer"
          } else if (hasRequestedVersion) {
          // if we've detected an acceptable version
          // embed the Flash Content SWF when all tests are passed
          AC_FL_RunContent(
          "src", "Hygeia",
          "FlashVars", "<%=params%>",
          "width", "100%",
          "height", "100%",
          "align", "middle",
          "id", "Hygeia",
          "quality", "high",
          "name", "Hygeia",
            } else {  // flash is too old or we can't detect the plugin
              var alternateContent = 'Alternate HTML content should be placed here. '
            + 'This content requires the Adobe Flash Player. '
             + '<a href=http://www.adobe.com/go/getflash/>Get Flash</a>';
              document.write(alternateContent);  // insert non-flash content
          </script>
          <noscript>
          id="example" width="100%" height="100%"
          <param name="movie" value="example.swf" />
          <embed src="example.swf" quality="high" bgcolor="#869ca7"
          width="100%" height="100%" name="example" align="middle"
          play="true"
          loop="false"
          quality="high"
          </embed>
          </object>
          </noscript>
          </body>
          </html>
          • 2. Re: SWF (Flex created) In JSP
            vksvicky Level 1
            saisri2k2, the code is nothing better than what I already have, it just won't display the flash movie!!
            • 3. Re: SWF (Flex created) In JSP
              Egyptian1993
              try to rename it .jsp
              or open it in dreamweaver and save it as jsp file
