4 Replies Latest reply on Dec 28, 2009 1:33 PM by ASJoke
    managing loadVars in html embeded swf
    ASJoke
      I am working with loadVars in an swf file embedded in
      an html page. The script is written to add a text string
      to existing textfield. The documentation I have does
      not address this situation. How do I get the return
      value from the server to the embedded SWF file in
      this situation?
      Thank you for time and attention;
      JK
        • 1. Re: managing loadVars in html embeded swf
          that's the typical situation.  what problem are you having?
          • 2. Re: managing loadVars in html embeded swf
            ASJoke Level 1
            I am developing an mp3 player (I have been posting to the AS 3 forum
            about it
            and you have responded with helpful info, there).
            In the Action Script 3.0 and 2.0 Flash player version 8 I am using
            externalInterface
            to load a play list from the html page. But as I write code around
            fsCommand() for
            version 7, I noticed that fsCommand() will not return a value to action
            script, so my
            work around is to use loadVars to get the play list directly into the
            swf player app.
            I thought I had seen the use of a loadVars attribute in the
            object/embed tag sets
            but I don't recall where I saw that and can't find it now.
            Oddly, when I load the swf directly into the browser, the version 7 swf
            code will work
            in Fire Fox on Mac OSX 1.5x with Flash version 10 plugin, But the
            version 7
            swf will not work in Fire Fox 1.5x with version 7 Flash plugin (on Mac
            OSX 1.3x).
            I am working with a local development server. I am using Flash CS4 and
            setting
            the publish settings to version 7 player. Each version has a container
            directory
            named 'V(version #). Javascript sniffs the Flash plugin version and
            loads the
            appropriate version in to the object/embed tag sets. I am generating
            versions
            with publish settings for 7,8,9, & 10.
            Thank you for your time and attention
            JK
            • 3. Re: managing loadVars in html embeded swf
              you mean flashvars, not loadvars.  the most common cause of a flashvars problem is the failure to define the variable(s) in all needed locations.
              with flashvars there are 3 places where you need to define your variable(s):  in a param tag, embed tag and the ac_fl_runcontent function.  have you done that.
              • 4. Re: managing loadVars in html embeded swf
                ASJoke Level 1
                Yes, of course, flashvars. I need to get a reference to documentation
                to find out how to use that.
                I will do a google search but I have flash_as2_learning.pdf ( based on
                doc downloaded from
                Adobe site, and Action Script 2.0 Language Reference, as well as
                O'reilly's Essential Action
                Script 2.0 and 3.0. As well I will have to get documentation on
                thank you for your time and attention;
                JK
