6 Replies Latest reply on Dec 29, 2009 12:29 PM by zzipper7
    Email workaround?
    zzipper7 Level 1
      SOAPBOX:
      I’m completely frustrated with the developments of ADDT and the lack interest by Adobe to help (why would they when they can sell us a new more expensive solution in a year) I love Adobe for some things but this is a real point of contention for me and my business.
      Gunter is a true hero and understands that we are all tied to the old system and will lose much while moving over to newer systems. He has saved me more times than I can count. My team and I are moving to http://codeigniter.com/ , I’m sure it will have its own set of issues, but at least I’ve chosen a direction.
      ISSUE
      Ok, down from my soapbox, I have real issues to be solved. I have many sites that the email is still failing, clients are angry and I don’t wish to rebuild sites for free. I read the 5.2.10 thread that had 3900+ views (hint hint Adobe) and I just don’t have time to fix ADDT.
      I want a simple work around. I have plenty of “mailto” scripts I trust for the moment.
      HOW CAN I TIE A FUNCTION TO THE END OF A REGISTRATION TRIGGER? If I could insert a simple function at the end of the registration insert  where the email trigger would normally go, I could move on with my life.
      I would need the last record inserted or the current function email var to send the email. I think this is a simple work around for broken sites.
      Anyone?
        • 1. Re: Email workaround?
          Günter Schenk Level 4
          I would try with defining your stuff within a Custom Trigger (type AFTER or END), because this one *is* actually a standard PHP function
          Cheers,
          Günter
          • 2. Re: Email workaround?
            zzipper7 Level 1
            I was unable to do this with the help files, would you be willing to provide an example function  (of any kind) and I should be able to work it out.
            James
            • 3. Re: Email workaround?
              Hi James,
              My creating a directory after inserting a record - tutorial is based on a pretty basic example which nonetheless may be a good starting point.
              Cheers,
              Günter
              • 4. Re: Email workaround?
                zzipper7 Level 1
                Ok ,that was somewhat helpful, thank you. If a can trouble you once more please.
                The old email function was:   $userRegistration->registerTrigger("AFTER", "Trigger_WelcomeEmail", 40);
                What I want to do:   $userRegistration->registerTrigger("AFTER", "MY_NEW_FUNCTION", 40);
                1. Is this syntax above correct?
                2. Where must the function be placed? Top of same page?
                3. Where will my variables come from for the new function ( I need to send the user their name and password) shouldn't the data be available in the previous insert function or should I take them from post data?
                Would my regular function trigger properly based on the syntax above and below here?
                function   MY_NEW_FUNCTION () {             // or does the function need a prefix "Trigger_ MY_NEW_FUNCTION"
                     $content = "{$email} & " ;  // use post data or vars from previous trigger??
                     DO EMAIL STUFF HERE;
                I appreciate your time, I think this post will help others too. I hope.
                James
                • 5. Re: Email workaround?
                  The syntax is indeed correct, however just in case you want to keep the existing Trigger_WelcomeEmail - Trigger, you d have assign a different "priority" value (better said: execution order) to your Custom Trigger, because you can´t have e.g. "40" for two triggers of the same type (AFTER/BEFORE).
                  the cool thing about PHP functions is, that they can be placed anywhere within the page.
                  Option 1: try with grabbing the main Insert Transaction´s transaction value like this: $tNG->getColumnValue("column_name")
                  Option 2, if 1) doesn´t work: try with grabbing the $_POST['fieldname'] data
                  nope :-)
                  Cheers,
                  Günter
                  • 6. Re: Email workaround?
                    zzipper7 Level 1
                    Thank you, so much once again. I still say that there needs to be a Gunter Donation Fund account somewhere!
                    Your clarifications helped, I thought the triggers were set to search a certain class in the includes, I wasn't aware I could use one to call a same page function. That really opens a ton of options.
                    Any feedback on codeigniter before I get to deep into it?
                    James Morris
                    Hotmail
