2 Replies Latest reply on Dec 30, 2009 2:22 PM by miguel8312
    POP-UP datagrid pass values to Main application
    miguel8312 Level 3
      I have two simple applications and i cant seem to get this to work i found a work around but is rather anoying.
      my first app does a call to a web service and retrieves info.
      main app looks like this
      <mx:Application
      xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" cornerRadius="7" backgroundGradientAlphas="[1.0, 1.0]" backgroundGradientColors="[#432A2A, #E96F6F]" height="700">
      <mx:Style
      source="b.css"/>
      <mx:Script>
      <![CDATA[
      import mx.managers.PopUpManager;
      import mx.containers.TitleWindow;
      import flash.geom.Point;
      private var point1:Point = new Point();
      private function showWindow():void {
      var win : WEBSERVICE2 = new WEBSERVICE2();
      PopUpManager.addPopUp(win,
      this,true);
      PopUpManager.centerPopUp(win);
      win.Query2=adrss;
      trace(win.Query2);
      </mx:Script>
      <mx:Form
      width="680" horizontalCenter="0" height="610" y="10">
      <mx:TitleWindow width="632" height="518" layout="absolute" horizontalCenter="0" horizontalAlign="center" verticalAlign="middle" showCloseButton="false" id="p_window" cornerRadius="10" title="Direct Pay">
      <textInput borderStyle="inset" themeColor="#0F0FF4" cornerRadius="7" id="adrss" borderColor="#0A0B0B" editable="false" enabled="true" x="85" y="37"/>
      </mx:TitleWindow>
      </mx:Form>
      </mx:Application>
      --------------pretty simple
      then the pop up window looks like this.
      <!--<mx:TitleWindow xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" backgroundGradientAlphas="[1.0, 1.0]" height="188" backgroundGradientColors="[#432A2A, #432A2A]">
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical" width="1220" height="365" cornerRadius="7" backgroundGradientAlphas="[1.0, 1.0]" backgroundGradientColors="[#432A2A, #E96F6F]">-->
      layout="
      vertical" width="1220" height="376"
      title="
      Vendor Query" horizontalAlign="center"
      showCloseButton="
      false">
      <!-- this is a comment i believe if i add creationComplete="initApp()" to the
      mx tag above then the function will start as soon as the application runs.-->
      <mx:Script>
      <![CDATA[
      import mx.controls.Text;
      // A reference to the TextInput control in which to put the result.
      // public var adrss:Text;
      // Event handler for the OK button.
      private function returnName():void {
      // loginName.text="Name entered: " + userName.text;
      PopUpManager.removePopUp(
      this);
      </mx:Script>
      <mx:Script>
      <![CDATA[
      import mx.controls.Alert;
      import mx.rpc.events.FaultEvent;
      import mx.rpc.events.ResultEvent;
      public function initApp():void {
      // Get Data from WebService and fill datagrid when you fist invoke the application
      trace("hello11111");
      //Getcheckdata(ws);
      ws.GetVendor(Query.text);
      private function GetVendor(event:ResultEvent):void {
      // Databind data from webservice to datagrid
      //ws.SaveEmployee(Query.text)
      datagrid.dataProvider = event.result;
      //chk.text= event.result.toString();
      //Alert.show(event.toString())
      //chk.text=ws.HelloWorld.toString
      trace("hello");
      private function fault(event:FaultEvent):void {
      // Oppps some error occured
      Alert.show(event.toString());
      trace("hello");
      private function AddRecord(event:MouseEvent):void {
      // Save a record using a WebService method
      //ws.SaveEmployee(txtEmpId.text, txtEmpName.text, txtEmpEmail.text); //
      </mx:Script>
      <mx:Script>
      <![CDATA[
      import mx.events.ListEvent;
      public var myArray:Array;
      // in which to put the result.
      public var adrss2:Text;
      Bindable]
      public var spriden_last_name:String;
      public var targetComponent:TextInput;
      private function list( e:ListEvent ):void {
      spriden_last_name =e.currentTarget.selectedItem.spriden_last_name;
      Query2.text=e.currentTarget.selectedItem.spriden_last_name;
      //adrss2=e.currentTarget.selectedItem.spriden_last_name;
      this);
      </mx:Script>
      <mx:WebService
      id="ws" wsdl="http://localhost:1571/WebSite6/Service.asmx?WSDL" fault="fault(event)">
      <mx:operation
      name="
      GetVendor"
      resultFormat="
      object"
      result="GetVendor(event)"
      </mx:WebService>
      <mx:DataGrid
      id="datagrid" width="1200" height="75%" borderColor="#913E48" themeColor="#A81E38" alternatingItemColors="[#943F3F, #B46969]" fontFamily="Arial" fontSize="12" borderStyle="none" alpha="0.99" textAlign="center"
      color="
      #131617" itemClick="list( event );" >
      <mx:columns>
      <mx:DataGridColumn headerText="Vendor Name" dataField="spriden_last_name"/>
      <mx:DataGridColumn headerText="state" dataField="spraddr_stat_code"/>
      </mx:columns>
      </mx:DataGrid>
      <mx:HBox width="558" height="35">
      <mx:Button label="Cancel" click="PopUpManager.removePopUp(this);"/>
      <mx:Button label="Button" click="initApp()" enabled="true"/>
      <mx:TextInput id="Query" height="26"/>
      <mx:TextInput id="Query2" height="26" visible="False"/>
      </mx:HBox>
      <!--<mx:TextInput id="chk"/>-->
      </mx:TitleWindow>
      the only way i seem to be able to make this work is by putting an invisible input box win.Query2=adrss; and set the reference to that on the parent APP but this just does not seem right I mean there is got to be a much easier way to do this. can anyone please lend a hand plus i rather not put boxes that im not going to use on my APP.
      Miguel
