10 Replies Latest reply on Dec 29, 2009 2:16 PM by jgaasbeek001
    Settings for exporting stills
    jgaasbeek001 Level 1
      If I remember correctly, PrE 4 allowed certain options to be set when exporting frames as pictures, such as the file format, aspect ratio and interlining. As my camera has native 16:9 lens and sensors (Sony HDR FX1), I had to set the aspect ratio to 1:1 in order to have my pictures in the right shape. Now I am missing these options, or am I looking at the wrong place?
        • 1. Re: Settings for exporting stills
          the_wine_snob Level 9
          Export>Frame>Settings will give you all of that. Here's a look at the various dialog boxes:
          Note: you will only see one dialog screen at a time, depending on the tab that you select. This is a composite.
          Hope that this helps,
          • 2. Re: Settings for exporting stills
            Hunt,
            This is not what I get to see when I start with the 'camera-icon' and than
            choose "export".
            Here is a screen shot of the file dialog box that I am being presented with:
            no options. Or should I activate the options elsewhere?
            Kind regards
            Jan Maarten Gaasbeek
            • 3. Re: Settings for exporting stills
              I do not use the "camera" icon, but will try it. I access the above by Export>Frame from the toolbar. Note: Export (Toolbar) is grayed out in PrE 8.
              Back in a moment,
              • 4. Re: Settings for exporting stills
                OK, from that camera icon, choose Export, which brings up the destination folder and file name dialog box. Look down the buttons on the lower-right for Settings (below Save and Cancel). There, you will get what I showed.
                PS - I had to hunt for that camera icon!
                • 5. Re: Settings for exporting stills
                  Hunt,
                  Thanks for all the effort, but in my software, there appear only 2 buttons
                  in the file select box: "Save" and "cancel". See attached screenshot.
                  Ps I am using a Dutch version, hope you understand what is in there
                  • 6. Re: Settings for exporting stills
                    Sorry, but I could not find the link to your screen-shot. You can use the little "camera" icon on the lower-middle of the editing screen's Toolbar.
                    Here are the screens and buttons that I get with the US version of PrE 4. Does your version language, your OS language and your keyboard language all match = Dutch?
                    Also, if you use the Toolbar and choose File>Export>Frame, do you get the settings screens?
                    Do you have WindowBlinds? That has caused problems with button displays on Adobe programs' dialog boxes. If so, get the update.
                    Have you updated your video driver very recently? If not, update from the card mfgr's site, or Dell's, or HP's site, if you have either of those computer makes.
                    Sorry that you are not seeing the buttons and the settings screens.
                    • 7. Re: Settings for exporting stills
                      Hunt,
                      Seems that this is yet another thing that is not working properly. Under
                      "File" there is no export function whatshowever. The only way to generate
                      output is saving the export file that is created after activating the camera
                      (as in your latest screenshot), or under the "share" options. Yes, I have
                      update my drivers, prior to that, I could not even run PrE 8 as you may
                      remember from my input in the thread "Is Premiere Elements 8 working
                      correctly for you?" I am not familiar with Windows Blinds, so I suppose I
                      don't have it. And yes, both OS and Adobe are Dutch versions. Could it have
                      something to do with renaming the file ad2m2ve.ax into ad2m2ve.ax.old as
                      suggested by Chad Baker in the thread "PE 8 causus problem with Windows
                      Media Center" Could that have anything to do with it? By the way, I still
                      have the media center functions disabled in the system configuration.
                      • 8. Re: Settings for exporting stills
                        Uh-oh,
                        You are on PrE 8. I had picked up the PrE 4 in the first post.
                        Export is dead in the Toolbar in PrE 8. All is from Share now. The screen-caps that I have been posting are from PrE 4, which is what I thought you were still using. Sorry about my confusion.
                        Seems that there's a thread on PrE 8 and still Export (Share now!). I'll see if I can find that, as it might have some useful info for you.
                        Back in a moment,
                        • 9. Re: Settings for exporting stills
                          Here's that recent THREAD.
                          Hope that something helps,
                          • 10. Re: Settings for exporting stills
                            Thanks Hunt, it is at least something. In my view still a pitty that they
                            threw overboard the nice and easy working settings option when using the
                            camera.
