1 Reply Latest reply on Dec 29, 2009 5:51 PM by Pii T
    RemoteObject component not hitting java method
    lakshdn Level 1
      I am using LCDS RemoteObject component to connect to my java classes. On start up i don't see any error in tomcat.
      However i am not able to invoke java method using this component.
      Can someone please help me if something is missing or wrong as i am stuck here, not able to figure out :-
      --remoting-config.xml -> definition
      <adapters>
           adapter-definition id="java-object" class="flex.messaging.services.remoting.adapters.JavaAdapter" default="true"/>
      </adapters>
      <default-channels>
           <channel ref="my-amf"/>
      </default-channels>
      <destination id="myDestId">
           <properties><source>com.sample.impl.MyJavaImpl</source></properties>
      </destination>
      --services-config.xml  -> definition
      <channels>
           <channel-definition id="my-amf" class="mx.messaging.channels.AMFChannel">
                <endpoint url="http://{server.name}:{server:port}/{context.rppt}/messagebroker/amf" class="flex.messaging.endpoints.AMFEndpoint"/>
           </channel-definition>
      </channels
      --calling mxml -> usage
      <mx:RemoteObject id="myRO" destination="myDestId">
           <mx:method name="javaMethod"/>
      </mx:RemoteObject>
      --calling line
      myRO.javaMethod.send();
      Any help is appreciated
        • 1. Re: RemoteObject component not hitting java method
          Pii T
          Edit: Sorry I didn't saw that you already set that. Ummm..... maybe some other guys might have a better idea.
          I'm not sure about LC but in BlazeDS you still have to tell it where the remote object is, specified in remoting-config.xml
          Ex.
          <destination id="Service">
                  <properties>
                      <source>Service.TestService</source>
                  </properties>
              </destination>
          In this case my .java is in blazeds's classes/Service and the file name is TestService.class
