2 Replies Latest reply on Jun 9, 2008 9:56 PM by mikem75
    Flash Text Input Component
    mikem75 Level 1
      Hello - I'm attempting to use the Flash Text Input component, but can't figure out how to get the text input! I see in the help files there's a event called "TextInput.enter" which is triggered when the user hits the enter key, but can't figure out how to work that event. I've been trying:
      on TextInput.trigger me
      put TextInput.text
      end
      but that just gets me an error message on the TextInput.trigger item. I'm sure this is simple, but I just can't figure it out. Any help?
      Mike M
      Director 11, Windows Vista Ultimate
        • 1. Re: Flash Text Input Component
          Level 7
          > put TextInput.text
          > end
          > sure this is simple
          It's /not/ simple - dealing with Flash Components rarely is! ;-)
          The component is designed to broadcast an event named #enter when the
          user presses the ENTER key, and an event named #change when the text
          changes. In order to catch this event, one would usually attach a
          behavior to the sprite with a handler name the same as the event name,
          but in the case of 'enter' it's a reserved word and the script won't
          compile:
          -- behavior attached to TextInput component:
          on change me
          put sprite(me.spriteNum).text
          end
          --on enter me
          -- put sprite(me.spriteNum).text
          --end
          My recommendation would be to use a regular #text member since you can
          trap the ENTER key in a keyDown handler, but it depends on what you're
          trying to achieve.
          • 2. Re: Flash Text Input Component
            mikem75 Level 1
            Thanks Sean - I think I get it now.
            Its unfortunate these components are so incredibly undocumented and clunky to use. At first glance they look like such elegant solutions.
            I think I'll stick to the tried-and-true regular text member as you suggest.
            Cheers!
            Mike M
