2 Replies Latest reply on Jan 4, 2010 7:18 AM by eli-s
    Convert PDF to Postscript
    eli-s Level 1
      I am trying the code athttp://livedocs.adobe.com/livecycle/es/sdkHelp/programmer/sdkHelp/wwhelp/wwhimpl/common/ht ml/wwhelp.htm?context=sdkHelp&file=convertPDFToPS.63.3.html
      import java.io.File;
      import java.io.FileInputStream;
      import java.io.InputStream;
      import java.io.FileNotFoundException;
      import java.util.Properties;
      import com.adobe.idp.Document;
      import com.adobe.idp.dsc.clientsdk.ServiceClientFactory;
      import com.adobe.livecycle.convertpdfservice.client.ConvertPdfServiceClient;
      import com.adobe.livecycle.convertpdfservice.client.enumeration.PSLevel;
      public class JavaAPIConvertPDFtoPS
           public static void main(String[] args)
                // Specify connection properties necessary to create a Distiller Service client
                Properties ConnectionProps = new Properties();
                ConnectionProps.setProperty("DSC_DEFAULT_EJB_ENDPOINT", "jnp://localhost:1099");
                ConnectionProps.setProperty("DSC_TRANSPORT_PROTOCOL", "EJB");
                ConnectionProps.setProperty("DSC_SERVER_TYPE", "JBoss");
                ConnectionProps.setProperty("DSC_CREDENTIAL_USERNAME", "administrator");
                ConnectionProps.setProperty("DSC_CREDENTIAL_PASSWORD", "password");
                // Create a ServiceClientFactory instance
                ServiceClientFactory factory = ServiceClientFactory.createInstance(ConnectionProps);
                try
                     // Get a PDF file document to convert to a PS document and populate a com.adobe.idp.Document object
                     String inputFileName = "C:\\test.pdf";
                     FileInputStream fileInputStream = new FileInputStream(inputFileName);
                     Document inDoc = new Document(fileInputStream);
                     // Perform the conversion and get the newly created document
                     Document createdDocument = new ConvertPdfServiceClient(factory).toPS(
                          inDoc,
                          PSLevel.LEVEL_3
                     // Save the file
                     createdDocument.copyToFile(new File("C:\\test.ps"));
                catch (Exception e)
                     System.out.println("Error OCCURRED: " + e.getMessage());
      This code is client code.  Is there an equivalent server side code, where there is no need to make any server connection?
