4 Replies Latest reply on Jan 4, 2010 7:02 AM by Jochem van Dieten
    Startup error on first run as non-administrator
    Jochem van Dieten Level 4
      I installed CFBuilder Beta 3 on a Windows XP SP3 machine in the standalone configuration from the Administrator account. At the end of the installation I choose not to start CFBuilder, but instead started it manually from my own user account (Power User group) on the system. The startup consistently gave an error. Removed CFBuilder, installed it again, same problem.
      Then I used the "runas" command to start CFBuilder as Administrator. CFBuilder started up correctly. Closed it, started CFBuilder from my own account. This time no error, but instead I was prompted to select a different workspace since the workspace was in use. After selecting a different workspace everything is fine now.
      Logfile from a startup error attached.
        • 1. Re: Startup error on first run as non-administrator
          Bhakti Pingale Level 2
          Hi Jochem,
          When you started CFB did the error come up as a pop-up message? If yes, what was the error message?
          From the logs this doesn't really seem to be an issue because CFB was not started with 'Run as Administrator' option.
          We will have a detailed look into the logs and get back.
          Thanks!
          Bhakti
          • 2. Re: Startup error on first run as non-administrator
            Bhakti Pingale wrote on 12/31/2009 7:56 AM:
            It said something like "The bundle could not be resolved." and pointed
            to the log file.
            I agree, usually when you have insufficient permissions you get a some
            io.SecurityException in the log, but this one is a bit weird.
            I don't think that all that many CF developers log in with a
            non-administrator account, so this may be a code path that gets
            exercised less frequently. I'll see if it is reproducible when I do a
            few more uninstall / install cycles this weekend.
            • 3. Re: Startup error on first run as non-administrator
              Thanks Jochem.
              We will try the same at our end.
              -Bhakti
              • 4. Re: Startup error on first run as non-administrator
                It is a permissions issue that is fixable by assigning additional
                permissions to the user. For now I have upgraded the Power Users group
                to Change permissions.
                Before:
                C:\Program Files\Adobe>cacls "Adobe ColdFusion Builder"
                C:\Program Files\Adobe\Adobe ColdFusion Builder BUILTIN\Users:R
                                            BUILTIN\Users:(OI)(CI)(IO)(special access:)
        GENERIC_READ
        GENERIC_EXECUTE
                                            BUILTIN\Power Users:C
                                            BUILTIN\Power Users:(OI)(CI)(IO)C
                                            BUILTIN\Administrators:F
                                            BUILTIN\Administrators:(OI)(CI)(IO)F
                                            NT AUTHORITY\SYSTEM:F
                                            NT AUTHORITY\SYSTEM:(OI)(CI)(IO)F
                                            PRLT-J002\Administrator:F
                                            CREATOR OWNER:(OI)(CI)(IO)F
                After:
        GENERIC_READ
        GENERIC_EXECUTE
                                            BUILTIN\Power Users:(OI)(CI)(IO)(special access:)
        DELETE
        READ_CONTROL
        SYNCHRONIZE
        GENERIC_READ
        GENERIC_WRITE
        GENERIC_EXECUTE
        FILE_GENERIC_READ
        FILE_GENERIC_WRITE
        FILE_GENERIC_EXECUTE
        FILE_READ_DATA
        FILE_WRITE_DATA
        FILE_APPEND_DATA
        FILE_READ_EA
        FILE_WRITE_EA
        FILE_EXECUTE
        FILE_READ_ATTRIBUTES
        FILE_WRITE_ATTRIBUTES
                With this change CFBuilder starts correctly.
                Jochem
