0 Replies Latest reply on Dec 30, 2009 6:10 AM by CadizVanery
    How to modify a pod in dashboard component?
    CadizVanery
      Hi
      I am new to flex and programming in general. So please do forgive me if I do not express my query clearly or with the right info.
      I am trying to build an application to show case photographs and one of the components I am using is the Dashboard built by WASI and can be seen here. It has several pods but I would like to have one of the pods load up with my own default position, width and height yet still retain the characteristics of minimizing, maximizing & drag and drop. Other than through the pods.xml file, I do not know how to modify (or which other file I should modify for that matter) so that when the application loads, it always starts with the particular pod at my desired height (top to bottom), width (about 1/4 of screen real estate) and position (left side of the screen)
      Below is the pods.xml file and attached is the project zip file.
      Used to specify the pod content in the dashboard sample app.
      To keep the implementation straightforward, all of the data is
      stored in this file rather than a database or separate XML files.
      <views>
              <view> - Represents a tab.
                  id - Must be unique so state can be saved properly.
                  label - The label of the tab.
                  <pod>
                      id - Must be unique per view so state can be saved properly.
                      type - Type of pod content. Valid values are chart, pieChart, form and list. "chart" and "pieChart" each have drill downs to one level.
                             "chart" is a fixed drill down to 30 days in a month.
                             "pieChart" is a fixed drill down to four geographical regions.
                      title - The title of the pod.
                      dataSource - The xml to load for the pod.
                      selectedViewIndex - Sets the default content view for pod content with a view stack.
                      valueField - For chart pods, the field from the xml data to use for displaying the value. This field should be numeric.
                      categoryField - For chart pods, the field from the xml data to use for displaying the category.
                      dataTipUnitLabel - Rollover label used for displaying the units.
                                         Label is delimited by "*" and places the first value before the unit and the second value after the unit. Ex: $50M.
                      dataTipLabelField - Rollover label field used for PieCharts.
                      labels - For form pods, used to label the fields.
                      dataFields - For form pods, used to assign the data fields to the form fields.
                                   The second field should always be a date expressed in milliseconds since the epoch.
          <view
              id="view0"
              label="Sales">
              <pod
                  id="pod00"
                  type="chart"
                  title="Yearly Revenue"
                  dataSource="data/revenue.xml"
                  selectedViewIndex="1"
                  valueField="value"
                  categoryField="month"
                  dataTipUnitLabel="$*M"
                  dataTipLabelField="month"/>
              <pod
                  id="pod06"
                  type="pieChart"
                  title="Revenue by Region"
                  dataSource="data/revenue_by_region.xml"
                  valueField="value"
                  categoryField="region"
                  dataTipLabelField="region"/>
              <pod
                  id="pod01"
                  type="chart"
                  title="Yearly Profit"
                  dataSource="data/profit.xml"
                  valueField="value"
              <pod
                  id="pod02"
                  type="form"
                  title="To Do"
                  dataSource="data/tasks.xml"
                  labels="Name,Date,Description"
                  dataFields="name,date,description" />
              <pod
                  id="pod03"
                  type="list"
                  title="Company News"
                  dataSource="data/news.xml" />
              <pod
                  id="pod04"
                  type="form"
                  title="Sales Pipeline"
                  dataSource="data/pipeline.xml"
              <pod
                  id="pod05"
                  type="chart"
                  title="Projected Revenue"
                  dataSource="data/projected_revenue.xml"
                  valueField="value"
          </view>
      Thank you very much for any help you may provide.
      Best regards
      Vanery
