1. Re: Clean Install PSE 8?
johnrellis Dec 30, 2009 11:39 AM (in response to faptexecdir)New versions of PSE coexist peacefully with older versions. The new version never replaces old versions. I recommend keeping the old versions around as long as you have the disk space, to ensure you're completely satisfied with the transition.
When you install PSE 8, it should ask to convert your PSE 4 catalog to PSE 8 format (leaving the original PSE 4 catalog untouched). If it doesn't ask, see this tech note for how to manually convert the catalog:
http://kb2.adobe.com/cps/515/cpsid_51536.html
PSE 8 will not change the dates of photos that you have changed. It may change the dates of video clips unless you make sure the Auto-Analyzer (a new feature) is disabled, which I highly recommend:
http://www.johnrellis.com/psedbtool/photoshop-elements-faq.htm#_Problems_with_the
