1 Reply Latest reply on Dec 30, 2009 10:49 PM by Sean_Wilson
    trying to convert VB to Lingo
    1210s
      hello,
      i am having difficulty converting the following VB code to lingo, appreciate it if someone could have a look:
      Dim lvLineName As String
      vRet = KDPhoneControl.GetLineName(1, lvLineName)
      Its an activex component which works fine other than i can't retrieve the linename
      below is taken from the components help
      KDPhone.GetLineName Method
      Description
      Retrieves the name of a specific telephony device.
      Parameters
      LineID (32-Bit Integer)
      The ID of the telephony device whose name you want to retrive. The valid values are 0 to KDPhone.NumberOfLines - 1.
      LineName (String, Output Parameter)
      If the function succeeds, this parameter is filled with the line device's name.
      Return Value (32-Bit Integer)
      If the function succeeds, the return value is zero.
      If the function fails, the return value is the code of the error occurred.
      I have tried using:
      sprite(1).GetLineName(1, member("line number"))
      but it doesnt work any help would be appreciated
      thanks
