7 Replies Latest reply on Jan 17, 2010 9:22 PM by miguelcdc
    Importing AVCHD video in .mp4 container from Samsung camcorder
    CDRUSA
      Hello anyone and everyone,
           I recently purchased a new Samsung camcorder (Model: HMX-H100N) and wish to use Premier Pro CS4 to edit the resulting video. The camcorder records video to an SDHC card in 1080i avc1 in an .mp4 container (the exact specifications as shown in GSpot and MediaInfo below) which when I attempt to import into premiere a green square is displayed. I have tried several AVCHD 1080i as well as HDV 1080i presets none of which have resulted in anything other than the green square or "Format Not Supported" error messages. I'm running Windows 7 (x86) OS and have several codecs (filters) installed including ffdshow, CoreAVC, DivX 7 as well as the built in Microsoft DTV-DVD filter and the MainConcept (adobe2) H264/AVC decoder. During normal playback of the .mp4 file Windows Meida Player seems to use the built in Microsoft DTV filter and playback is flawless, I would assume that Premier is attempting to use the MainConcept filter which seems to be unable to decode the files. Any help is appreciated.
      MediaInfo:
      Format                           : AVC
      Format/Info                      : Advanced Video Codec
      Format profile                   : Main@L4.0
      Format settings, CABAC           : Yes
      Format settings, ReFrames        : 4 frames
      Codec ID                         : avc1
      Codec ID/Info                    : Advanced Video Coding
      Duration                         : 9mn 38s
      Bit rate mode                    : Variable
      Width                            : 1 920 pixels
      Height                           : 1 080 pixels
      Display aspect ratio             : 16:9
      Original display aspect ratio    : 16:9
      Frame rate mode                  : Constant
      Frame rate                       : 29.970 fps
      Resolution                       : 24 bits
      Colorimetry                      : 4:2:0
      Scan type                        : Interlaced
      Scan order                       : Top Field First
      Stream size                      : 1.14 GiB (99%)
      Title                            : SAMSUNG AVC
      GSpot:
      Container:
      avc1: MP4 Base w/ AVC ext [ISO 14496-12:2005]
      - isom: MP4  Base Media v1 [IS0 14496-12:2003]
      Recommended Display Size: 1920 x 1080
      Video:
      Codec: avc1 Name: H.264/MPEG-4 AVC
      Pics/s: 29.971 Frames/s: 29.971
      1920 x 1080 sar: 1.778 (16:9) dar: 1.778 (16:9)
