1 Reply Latest reply on Sep 24, 2010 3:27 AM by Sivakami Rajan
    Getting Channel Ping Failed Error after disabling Browser cookies using Blazeds
    ragini3 Level 1
      Hello All,
      I am using Flex 3.3 , Blazeds 3.3.0.9520 in my application.When I disable the browser cookies I got the errors in fault handler of the Remote Object.
      Errors in Detail :
      1] [FaultEvent fault=[RPC Fault faultString="Detected duplicate HTTP-based FlexSessions, generally due to the remote host disabling session cookies. Session cookies must be enabled to manage the client connection correctly."
      faultCode="Server.Processing.DuplicateSessionDetected" faultDetail="null"] messageId="74FCAA7C-6508-76B5-
      8BD1-AB2694B1D08E" type="fault" bubbles=false cancelable=true eventPhase=2]
      2] [FaultEvent fault=[RPC Fault faultString="Send failed" faultCode="Client.Error.MessageSend"
      aultDetail="Channel.Ping.Failed error null url: 'http://192.168.1.76:8080/messagebroker/amf'"] messageId="963746F4-07A8-B1B6-09D4-DEE3BF9EDCD3"
      Is there any way to use Blazeds by disabling the browser cookies?
      If you want more information , please let me know.
      Awaiting for prompt reply!
      Thanks and Regards,
      Ragini.
        • 1. Re: Getting Channel Ping Failed Error after disabling Browser cookies using Blazeds
          Sivakami Rajan
          I was facing the same issue in my application.  I our case the error occured while navigating from one module to another.
          I resolved it with the following solution.
          1. In services-config.xml,
          add <invalidate-session-on-disconnect>true</invalidate-session-on-disconnect> in the channel definition as below
          <channel-definition id="my-amf" class="mx.messaging.channels.AMFChannel">
          <endpoint url="http://{server.name}:{server.port}/{context.root}/messagebroker/amf" class="flex.messaging.endpoints.AMFEndpoint"/>
          <properties>
          <polling-enabled>false</polling-enabled>
          <add-no-cache-headers>true</add-no-cache-headers>
          </properties>
          </channel-definition>
          2. Then after each RemoteObjectcall , disconnect the connection in the result handler and fault handler of the RemoteObject.
          example : myRemoteObject.disconnect().
          Sivakami
