6 Replies Latest reply on Jan 5, 2010 10:56 PM by LaVengeance
    Disable the background except textfield
    imranv10
      Hi  My requirement is to disable background but I can edit 4 textfields at the same  time. If I disable the Application.application.enabled=false and then try to  enable textfield it is not working. Is there any way through which I can achieve  my target?
      Imran
        • 1. Re: Disable the background except textfield
          LaVengeance Level 1
          You can do something like this:
          {code}
          var a:Array = application.getChildren();
                      for(var i:int = 0; i<a.length ; i++){
                          var obj:Object = a[i];
                          if(obj.id != "id1" && obj.id != "id2" && obj.id != "id3" && obj.id != "id4"){
                              obj.enabled = false;
          {code}
          replace id1, id2, id3 and id4 with the IDs of your four text fields, hence all the components except the 4 will be disabled.
          Cheers
          • 2. Re: Disable the background except textfield
            imranv10 Level 1
            Thanks for the reply
            But my problme is slight different
            In my default mxml file, I have put one component called BubbleContainer whose id id "bbl"
            And this component contains the textfields
            {code}
            package component
            // import statements
            public class BubbleContainer extends UIComponent
                 public var txtRadial1 : TextInput = new TextInput();
                 public var txtRadial2 : TextInput = new TextInput();
                 public var txtRadial3 : TextInput = new TextInput();
            // mxml file
            <mx:HBox id="hbxMain" width="100%" height="100%" verticalGap="0" horizontalGap="0">
            <mx:HBox id="hbxBubble" width="100%" height="100%" mouseMove="{mouseMoveOnBbl(event);}"  verticalGap="0" horizontalGap="0">
            <component:BubbleContainer creationComplete="{setOriginalSize();}" mouseMove="{mouseMoveOnBbl(event);}"
            resize="{ reload();  }"
            id="bbl" width="100%" height="100%"  keyUp="{application_onKeyUp(event)}"  />
            </mx:HBox>
            {code}
            Any help will be appreciated
            Imran
            • 3. Re: Disable the background except textfield
              LaVengeance Level 1
              can't you enable your entire component ( bbl ) ? try doing this :
              {code}
                              if(obj.id != "bbl"){
              {code}
              If your requirement is different , please be more specific as to exactly which items you'd want to diable and post the entire code here, HTH ..
              Cheers
              • 4. Re: Disable the background except textfield
                Umal Kumar Adobe Employee
                Can you please provide some sample application so that i can try it on my end and suggest some resolution? Also as per the request i can understand that you want everything to be disabled except the text fields. Can you clarify on this a little bit more?
                UKB
                • 5. Re: Disable the background except textfield
                  imranv10 Level 1
                  I can disable bbl component. But that will disable text fields as well.
                  bbl component which is included in mxml file contains sprite, circle and text fields.
                  I want to disable everything on the screen except these text fields
                  If I will disable bbl component then it will disable circle and text fields and all children of bbl.
                  But I want to enable text fields.
                  I hope this will clear the air.
                  Imran
                  • 6. Re: Disable the background except textfield
                    LaVengeance Level 1
                    create a public function in the bbl
                    component which disables all the child components except for the 4 text fields... call this function once you disable all components of your applicaiton except bbl..
                    something like this :
                    {code}
                              bbl.disableComponents();     // write this public method inside the bbl component class which will disable all children except the 4
        // text fields
                    {code}
