3 Replies Latest reply on Jul 8, 2010 3:15 AM by Schwarz Boris
    CFTree refresh
    Kaias26
      Hello
      I have a CFTree bind with a CFC (classic) :
      <cfform name="formRootNode" format="html" style="margin:0px;">
          <cftree name="RootNode" height="400" width="200" format="html">
              <cftreeitem bind="cfc:_cfc.cTree.getNodes({cftreeitemvalue},{cftreeitempath})">
          </cftree>
      <cfinput type="button" name="btnRefresh" value="test" onclick="javascript:(ColdFusion.Tree.refresh('RootNode'));" />
      </cfform>
      but when I click on the refresh button i have an error and i don't know why :
      " _1b.parent is null " (/CFIDE/scripts/ajax/package/cftree.js, line 219)
      Does anyone know how to fix it ?
      PS : I work with coldfusion 9
        • 1. Re: CFTree refresh
          Schwarz Boris Level 1
          I was having the same problem during the last days and hacking into /CFIDE/scripts/ajax/package/cftree.js is the only solution I can come up with:
          Look for the function "ColdFusion.Tree.formPath" (line 214) and manipulate it as following:
          ColdFusion.Tree.formPath=function(_1b,_1c){
          var _1d=ColdFusion.objectCache[_1b.tree.id+"collection"];
          if(_1d.completepath==true&&_1b.isRoot()){
            return "";
          }else{
            if(_1b.parent==null) return ""; // Adding this line removes the error
            if(_1d.completepath==false&&_1b.parent.isRoot()){
             return "";
          if(!_1c){
            _1c=_1b;
          var _1e=ColdFusion.Tree.formPath(_1b.parent,_1c);
          _1e=_1e+_1b.data.id;
          if(_1c.data.id!=_1b.data.id){
            _1e=_1e+_1d.delimiter;
          return _1e;
          Makes the <cftree> refresh, but closes all nodes on my binded tree. But that's probably how it's supposed to be... Hopefully others find this helpful.
          Cheers, Boris
          Edit:
          You could probably just add this function to your regular JavaScript and override the CF-generated one. Manipulating CFIDE could affect others of your application.
          Message was edited by: Schwarz Boris
          • 2. Re: CFTree refresh
            Kaias26 Level 1
            hi Boris, thanks for your answer but i have found a better way to solve my problem :
            when i update my tree (change or delete a node for exemple), i call a js function :
            ColdFusion.Tree.loadNodes([],{'treeid':"RootNode",'parent':mynodeparent});
            mynodeparent.expand();
            var :
            var oTree = ColdFusion.Tree.getTreeObject('RootNode');
            var currentNode=oTree._cf_node;
            var mynode=oTree.getNodeByProperty('id',currentNode);
            var    mynodeparent = mynode.parent;
            LoadNodes refresh only the parent node (and all their children inside), then i expand the parent (so that will not close my other nodes )
            \0/
            • 3. Re: CFTree refresh
              Awesomeness! That's even cooler than ColdFusion.Tree.refresh. The only issue I'm having is when I need to reload a node that hasn't got a Parent-Node.
              I guess I'll have to go with ColdFusion.Tree.refresh in that special case.
              But anyway, thanks for your solution.
