7 Replies Latest reply on Jun 19, 2008 3:01 AM by
    rounded edges
    Level 7
      I wanted to make a simple square image have maybe one or two rounded corners
      and was stuck trying to figure out how to do this. Is this simple or am I
      missing something obvious? I'm using FWMX and was looking for something
      similar to the flash images on the right of this site where two of the
      corners are rounded. http://www.madderns.com.au/web/
      Any pointers tutorials would be really appreciated.
      Brian
        • 1. Re: rounded edges
          Level 7
          dw2004 wrote:
          > Hi,
          Use the Rounded Rectangle tool--which you'll find if you press and hold
          on the vector rectangle tool--to draw the square. Press Alt/Opt to
          change the radius of individual corners.
          Linda Rathgeber [PVII] *Adobe Community Expert-Fireworks*
          http://www.projectseven.com
          Fireworks Newsgroup: news://forums.projectseven.com/fireworks/
          CSS Newsgroup: news://forums.projectseven.com/css/
          http://www.adobe.com/communities/experts/
          • 2. Re: rounded edges
            Level 7
            Thanks Linda,
            My problem is that the image is already imported and made up and it's to
            this I was hoping to tweak the corners. Is that still what you recommend?
            Brian
            "Linda Rathgeber" <lightly@sc.rr.com> wrote in message
            news:g2lp7h$q2s$1@forums.macromedia.com...
            > dw2004 wrote:
            >> Hi,
            >> corners and was stuck trying to figure out how to do this. Is this simple
            >> or am I missing something obvious? I'm using FWMX and was looking for
            >> something similar to the flash images on the right of this site where two
            >> of the corners are rounded. http://www.madderns.com.au/web/
            > Use the Rounded Rectangle tool--which you'll find if you press and hold on
            > the vector rectangle tool--to draw the square. Press Alt/Opt to change the
            • 3. Re: rounded edges
              thegendreamer Level 1
              wow that info was just what i was looking for
              • 4. Re: rounded edges
                SiamJai Level 2
                You could still use that rounded rectangle, to mask your imported image. Just select both objects and then click Modify >> Mask >> Group as mask.
                Make sure that the imported image is on top of the rounded rectangle, otherwise it won't work quite as intended. ;-)
                SiamJai
                http://design.thaiwonders.com - Innovative Fireworks & Game Art Community
                • 5. Re: rounded edges
                  Level 7
                  Thanks a mil,
                  That worked a treat!
                  Brian
                  "SiamJai" <webforumsuser@macromedia.com> wrote in message
                  news:g2m543$a2s$1@forums.macromedia.com...
                  > Just
                  > SiamJai
                  • 6. Re: rounded edges
                    geeturs
                    good info m8 thanks
                    • 7. Re: rounded edges
                      my issue is fixed by the advices i got from you. do me a favour by giving a little more information on the topic.
