1 Reply Latest reply on Dec 31, 2009 1:34 PM by hrfrerich
    Emailing A File
    myjkem2
      I have to send a PDF of the map I am working on to a customer.
      Not for printing on a press, just to look at.
      Sometimes when people send me PDF's they have been able to
      make them a small file and email it to me and they are easy to read.
      I can't seem to make my Illustrator PDF small enough to email.
      Also I want the PDF fixed so they can't edit it.
        • 1. Re: Emailing A File
          hrfrerich Level 1
          What version of Illustrator do you have? I have CS4
          When i save to pdf a pop-up box prompts me with pdf options.
          - set "Adobe PDF preset" to "smallest file size"
          - uncheck "preserve illustrator editing capabilities"
          - adjust compression settings in the "compression" tab
          - go to the "security" tab and check "use password to restrict editing"
          - here you can set more options like what they can copy (if anything) and printing resolution
          - save
          this will save a perfect scalable reproduction of your work, and i dont think they will be able to edit it (could be wrong)
          If you dont get the diolouge box in illustrator when saving (or for ultimate protection):
          - select all artwork
          - object menu > rasterize
          - adjust resolution for desired quality
          - your artwork is now a pixel image (dont save it as your illustrator file!)
          - save as pdf file (with restrictions if you want)
          If all else fails, you can open the pdf in acrobat and add security though "advanced" > "security" and reduce file size through "document" > reduce file size"
          To check how hard your artwork is to modify:
          - use a screenshot of the pdf or open the pdf in illustrator
          - see if you can move anything, if yes you use the rasterization method
          - use live-trace if it's a pixel image
          has damage been done using live trace? if your disgn is simple enough to live-trace from a pixelated image there is no hope for true security.
