13 Replies Latest reply on Feb 3, 2010 10:30 PM by jackscon joseph
    DVD Burn error - unknown error 2130903552 or 2130906240
    ri-olson
      Burn a movie from PRE 8 also similar from old PRE 3 and I get the above error almost at the end of the blue line showing burn progress.  I have tried different brand discs and 3 different DVD drives on external (Sony).  I have AMD processor dual and windows XP.
        • 1. Re: DVD Burn error - unknown error 2130903552 or 2130906240
          Are you able to burn to a folder on your hard drive rather than directly to a disc?
          The FAQs to the right of this forum offer more suggestions for troubleshooting your issue.
          http://forums.adobe.com/thread/415318?tstart=0
          If you'll post your results for each step in as much detail as possible, we can help you diagnose your problems and recommend solutions.
          • 2. Re: DVD Burn error - unknown error 2130903552 or 2130906240
            the_wine_snob Level 9
            Please give us the full specs. of your computer, your source files and also your Project Preset. A description of the Menu Set used, and how you set up your DVD Markers could also be useful.
            Good luck, and we'll be looking for that info.
            • 3. Re: DVD Burn error - unknown error 2130903552 or 2130906240
              Here's an ARTICLE on one of the errors on the Roxio forum.
              Maybe something there will be helpful.
              • 4. Re: DVD Burn error - unknown error 2130903552 or 2130906240
                Here is an ARTICLE from the Muvipix forum on the same error.
                • 5. Re: DVD Burn error - unknown error 2130903552 or 2130906240
                  Here is an ARTICLE, again from Roxio, and it has many links that look useful.
                  • 6. Re: DVD Burn error - unknown error 2130903552 or 2130906240
                    Here's another ARTICLE from Muvipix on your second error message.
                    • 7. Re: DVD Burn error - unknown error 2130903552 or 2130906240
                      ri-olson Level 1
                      I was able to burn to a folder on my hard drive.  I am not sure how to take
                      that file and burn a DVD.  What program can I use to de that?  Is there one
                      in Windows XP?  I used to use Roxio program, but when I tried updating to
                      version 7 a while back I had so much problems with the software I dumped it.
                      • 8. Re: DVD Burn error - unknown error 2130903552 or 2130906240
                        I would use the freeware burning utility, ImgBurn, to do the physical burning. Note: there are ads on that page for other software. You want ImgBurn and not something else. It's small, simple to use, and will actually allow more flexibility, than will PrE.
                        • 9. Re: DVD Burn error - unknown error 2130903552 or 2130906240
                          ri-olson Level 1
                          I tried using Imgburn and was not successful.  I tried to burn the folder to
                          disc, I hope that was the right one.  Here is the data that it recorded
                          This may be to much information, thanks for your help.
                          I 20:40:55 ImgBurn Version 2.5.0.0 started!
                          I 20:40:55 Microsoft Windows XP Media Center Edition (5.1, Build 2600 :
                          Service Pack 3)
                          I 20:40:55 Total Physical Memory: 2,030,060 KB  -  Available: 272,404 KB
                          W 20:40:55 Drive F:\ (FAT32) does not support single files > 4 GB in size.
                          I 20:40:55 Initialising SPTI...
                          I 20:40:55 Searching for SCSI / ATAPI devices...
                          I 20:40:55 Found 1 DVD-ROM, 1 DVD±RW and 1 DVD±RW/RAM!
                          I 20:45:34 Operation Started!
                          I 20:45:34 Building Image Tree...
                          I 20:45:38 Checking Directory Depth...
                          I 20:45:38 Calculating Totals...
                          I 20:45:38 Preparing Image...
                          I 20:45:38 Checking Path Length...
                          I 20:45:38 Contents: 8 Files, 2 Folders
                          I 20:45:38 Content Type: DVD Video
                          I 20:45:38 Data Type: MODE1/2048
                          I 20:45:38 File System(s): ISO9660, UDF (1.02)
                          I 20:45:38 Volume Label: 20100101_214542
                          I 20:45:38 IFO/BUP 32K Padding: Enabled
                          I 20:45:38 Region Code: 1, 2, 3, 4, 5, 6, 7, 8
                          I 20:45:38 TV System: NTSC
                          I 20:45:38 Size: 1,496,080,384 bytes
                          I 20:45:38 Sectors: 730,508
                          I 20:45:38 Image Size: 1,496,678,400 bytes
                          I 20:45:38 Image Sectors: 730,800
                          I 20:45:47 Operation Successfully Completed! - Duration: 00:00:13
                          I 20:45:47 Operation Started!
                          I 20:45:47 Source File: -==/\/[BUILD IMAGE]\/\==-
                          I 20:45:47 Source File Sectors: 730,800 (MODE1/2048)
                          I 20:45:47 Source File Size: 1,496,678,400 bytes
                          I 20:45:47 Source File Volume Identifier: 20100101_214542
                          I 20:45:47 Source File Application Identifier: IMGBURN V2.5.0.0 - THE
                          ULTIMATE IMAGE BURNER!
                          I 20:45:47 Source File Implementation Identifier: ImgBurn
                          I 20:45:47 Source File File System(s): ISO9660, UDF (1.02)
                          I 20:45:47 Destination Device: HP DVD Writer 840b HI86 (G:) (ATA)
                          I 20:45:47 Destination Media Type: DVD-R (Disc ID: CMC MAG. AM3) (Speeds:
                          4x, 8x, 12x, 16x)
                          I 20:45:47 Destination Media Sectors: 2,297,888
                          I 20:45:47 Write Mode: DVD
                          I 20:45:47 Write Type: DAO
                          I 20:45:47 Write Speed: MAX
                          I 20:45:47 Link Size: Auto
                          I 20:45:47 Lock Volume: Yes
                          I 20:45:47 Test Mode: No
                          I 20:45:47 OPC: No
                          I 20:45:47 BURN-Proof: Enabled
                          I 20:45:48 Filling Buffer... (40 MB)
                          I 20:45:49 Writing LeadIn...
                          I 20:46:11 Writing Session 1 of 1... (1 Track, LBA: 0 - 730799)
                          I 20:46:11 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 730799)
                          W 20:46:33 Failed to Write Sectors 6304 - 6335 - Reason: Invalid Address For
                          Write
                          W 20:46:33 Retrying (1 of 20)...
                          W 20:46:33 Retry Failed - Reason: Invalid Address For Write
                          W 20:46:33 Retrying (2 of 20)...
                          W 20:46:33 Retrying (3 of 20)...
                          W 20:46:33 Retrying (4 of 20)...
                          W 20:46:33 Retrying (5 of 20)...
                          W 20:46:33 Retrying (6 of 20)...
                          W 20:46:33 Retrying (7 of 20)...
                          W 20:46:33 Retrying (8 of 20)...
                          W 20:46:33 Retrying (9 of 20)...
                          W 20:46:33 Retrying (10 of 20)...
                          W 20:46:33 Retrying (11 of 20)...
                          W 20:46:33 Retrying (12 of 20)...
                          W 20:46:33 Retrying (13 of 20)...
                          W 20:46:33 Retrying (14 of 20)...
                          W 20:46:33 Retrying (15 of 20)...
                          W 20:46:33 Retrying (16 of 20)...
                          W 20:46:33 Retrying (17 of 20)...
                          W 20:46:33 Retrying (18 of 20)...
                          W 20:46:33 Retrying (19 of 20)...
                          W 20:46:33 Retrying (20 of 20)...
                          E 20:47:29 Failed to Write Sectors 6304 - 6335 - Reason: Invalid Address For
                          Write
                          E 20:47:29 Next Writable Address: 0
                          I 20:47:29 Synchronising Cache...
                          W 20:47:50 User opted to skip the 'Close Track/Session/Disc' functions.
                          E 20:47:50 Failed to Write Image!
                          I 20:47:50 Exporting Graph Data...
                          I 20:47:50 Graph Data File: C:\Documents and
                          Settings\HP_Administrator\Application Data\ImgBurn\Graph Data
                          Files\HP_DVD_Writer_840b_HI86_SATURDAY-JANUARY-02-2010_8-45_PM_CMC_MAG._AM3_
                          MAX.ibg
                          I 20:47:50 Export Successfully Completed!
                          E 20:47:50 Operation Failed! - Duration: 00:02:02
                          I 20:47:50 Average Write Rate: 163 KB/s (0.1x) - Maximum Write Rate: 1,011
                          KB/s (0.7x)
                          • 10. Re: DVD Burn error - unknown error 2130903552 or 2130906240
                            ImgBurn is a very lenient burning program. If it is having problems, then there is likely an issue with your burner.
                            The first thing that I would do would be to check for firmware updates for the burner. If that does not help, then I would go to Control Panel>System>Hardware>Device Manager, and remove the burner. Then, reboot, and let the OS find the burner and install it. Test again.
                            If that does not work, you might want to think about a new burner.
                            • 11. Re: DVD Burn error - unknown error 2130903552 or 2130906240
                              jackscon joseph
                              This error is displaying because of two reasons 1. Bad DVD writer or  Bad disk. Please change the disk and burn a DVD.
                              • 12. Re: DVD Burn error - unknown error 2130903552 or 2130906240
                                nealeh Level 5
                                Service Pack 3)
                                <snip>
                                Write
                                <snip>
                                Write
                                <snip>
                                I've had that problem with ImgBurn. I use the predecessor of ImgBurn - DVD Decrypter - it is more tolerant. It does not  decrypt modern DVDs but is still a great tool for disk writing.
                                Cheers,
                                Neale
                                • 13. Re: DVD Burn error - unknown error 2130903552 or 2130906240
                                  jackscon joseph Level 1
                                  This will display beacuse of two reasons.
                                  1. Damaged disk user for burning.
                                  2. DVD writer/driver must have some issues.
