0 Replies Latest reply on Jan 2, 2010 5:31 AM by Anne Tuohy
    Setting input fields to an empty string BIG PROBLEM
    Anne Tuohy
      Hi Rob, thanks for your rerply, It makes sense alright, but I am using 2 seperate input fields. I have discovered what is causing the problem .
      After the user types into the inputfield and moves on to a different frame, I have set the input field to an empty string and this is what is causing the problem.
      I have tried setting the input field to an empty string in a movie script and on individual sprites and the first right answer is not excepted.I have to type in the right answer twice to get get a right response. I am actually using three seperate input fields in total, each with a different name and behavior. Even If I use one input field I still have the same problem. Its driving me crazey. Any Ideas.
      Anne
