1 Reply Latest reply: Jan 2, 2010 8:42 PM by CtDave RSS
    Are Tags neccessary?
    woodstockjay Community Member
      Are tags neccessary for a multple page PDF to work properly?  Navigation from page to page is done with links.  I get an error message "incorrect structure" on some of the pages WITH tags until I remove them, then the file works properly?
        • 1. Re: Are Tags neccessary?
          CtDave CommunityMVP
          Tagged PDF:
          --| for accessibility
          --| for reflow
          --| for an export to other applications that retains format/layout
               (for 'good' export, need to master content in the authoring file correctly).
          --| for simple copy and paste into other applications with retention of simple format/layout retained.
          If Tagged PDF is not needed then, in the authoring application, "turn off" accessibility support.
          In MS Word, use Adobe PDFMaker or, in Word 2007, uncheck "accessibility" selection of Options in the Save As PDF or XPS dialog.
          If you do need a tagged output PDF, for whatever reason, then what you have is a malformed tagged PDF.
          You will have to return to the authoring file to make corrections.
          Be well...
