4 Replies Latest reply on Jan 4, 2010 7:21 AM by the_wine_snob
    PE3 -vs- PE7:  Low Resources
    Last Minute Video Level 1
      Recently upgraded from PE3 to PE7...
      For almost 2 yrs, I used PE3 to create all sorts of videos with various lenghts. Many w/video clips, photos, music, effects & transitions.
      Never did I have a crash; never was I warned that my resources were low. I've always had a separate Drive exclusively for my video clips.
      Now, my first project in PE7 and throughout the 25 min. video/photo/music project, a warning message popped up telling me that my resources were extremely low and that I should save and proceed with caution.
      What changed and/or what can I do to resolve this issue?
      Thanks!
      John
      "Last Minute Video Productions"
      sr71@comcast.net
        • 1. Re: PE3 -vs- PE7:  Low Resources
          the_wine_snob Level 9
          I do not know how the resource load might differ between PrE 3 & 7, but this ARTICLE might give you some tips on getting the most out of your computer, regardless of version number. I use these tips for any NLE editing session, and I am using PrPro, so the tips are not version, or even program specific.
          Hope that this helps,
          • 2. Re: PE3 -vs- PE7:  Low Resources
            With "resources," one needs to also consider that there are basically two types:
            1.) physical RAM installed, how the OS accesses that and how the program accesses that
            2.) Windows Virtual Memory (Page File), how the OS manages that, where it's located and what else is accessing it.
            That is where the previous article comes in - those tips will eliminate unnecessary programs and Processes, from accessing either, sapping your NLE of necessary "resources."
            For NLE work, I choose to have my Page File set as static (not dynamically managed by the OS), set to ~ 2.5x my installed RAM (4GB on a 32-bit OS) and located where I get the greatest speed. On my workstation, I have it split over my C:\ & E:\ drives. On my laptop, it's split over my C:\ & D:\ drives. It took a lot of testing and benchmarking to establish these locations. Most find that locating it on a C:\, with only the OS and programs, will give more than adequate results. What too often happens is that people will partition a single physical HDD, or only have a single physical HDD, and everything is trying to access that single physical HDD at once, hence a major bottleneck, with slowdowns and even crashes.
            I recommend that an editing computer have a minimum of 3 physical (not partitions of any sort) HDD's, and that they are allocated thusly:
            C:\ OS, programs and maybe Page File
            D:\ media only
            E:\ Project files, Scratch Disks, etc.
            Note: one could easily swap D:\ for E:\ in their role. That is just how I have things set up on my computers.
            • 3. Re: PE3 -vs- PE7:  Low Resources
              And don't forget to resize those photos to no larger than 1000x750 pixels, per the FAQs to the right of this forum. Oversized photos are the main reasons this program shows out of memory messages.
              You should also render regularly (by pressing the Enter key) so that any red lines along the top of your timeline turn green.
              • 4. Re: PE3 -vs- PE7:  Low Resources
                If one does need to resize large stills, this ARTICLE will give them tips on automating the process in Photoshop.
