6 Replies Latest reply on Jan 4, 2010 2:10 AM by Michel Bozgounov
    Design
    hiwaar
      I wounder what is the best adobe design product for ads and banners
        • 1. Re: Design
          daaave Level 2
          for print or for the web?
          • 2. Re: Design
            hiwaar Level 1
            Thank you for your answer
            We need it for the web
            our website is at
            http://www.hiwaar.com
            and we would like to create a banner with html code, so we can display it on other sites
            • 3. Re: Design
              pixlor Level 4
              If you need code within the banner, then you need Flash.
              • 4. Re: Design
                hiwaar Level 1
                Thanks, you mean adobe flash player? I am a bit confused, if you could explain
                it a bit more. Thanks
                • 5. Re: Design
                  pixlor Level 4
                  No, I mean Flash, the application that is used to create Flash animations: http://www.adobe.com/products/flash/ .
                  Images are static objects. They are rectangular grids of colors. If you want an object that users can interact with, then you need a dynamic Flash animation. More to the point. If you don't know what Flash is, then you need to hire someone who knows Web marketing and the use of banner advertisement as well as a designer/programmer who can make them.
                  • 6. Re: Design
                    Michel Bozgounov Level 2
                    You mentioned "HTML code", actually...
                    What you need is, I suppose:
                    1) an image (the banner -- small static image -- JPG, PNG, GIF, or animated GIF image),
                    2) a bit of HTML to show the image + link to your site on other sites.
                    Something like:
                    <a href="http://www.YOURDOMAIN.com/" title="Why not see our great company site?">
                      <img src="http://www.YOURDOMAIN.com/images/banners/banner-01.gif" border="0" alt="" />
                    </a>
                    Am I right?
                    If you need this, then:
                    1) Adobe Fireworks will be perfect for you to create the banner(s) -- Fireworks is the tool for screen use; it can also easily animate small GIF files. If you need a non-animated static image, Photoshop or Illustrator will do the job, too.
                    2) You do not need a code editor for this -- the code example I posted is enough. Simply copy and paste, modify the paths, and you're done!
                    If you need something more complex -- Flash animations/banners, which will be embedded, and will link to your site or promo page, then I can't help, and you better go to the Adobe Flash forums
                    Cheers!
