1 Reply Latest reply on Jan 4, 2010 6:47 AM by carl schooff
    how best to animate the growing stems of some flowers?
    nickharambee Level 1
      hi
      i am designing an animated flash webpage, and would like some advice on the best way to animate the growing stalk of some 'flowers'.  I have watched an online tutorial on drawing curved lines, and in this tutorial the line was drawn using a mask manually, i.e. the mask was transformed manually for each frame, which is OK for a few frames, but I would rather do this automatically if possible, as there will be 8 lines and quite a lot of frames.  The trouble with say creating a motion tween for the mask layer is that this doesn't give enough control with curvy lines. So I was wondering if there is another way, either in Flash CS4 or After Effects CS4.  For instance, is there such a thing as a fill/stroke tween, which would fill a predefined line with a particular colour at a variable rate?  Here is a rough draft of the kind of page I am wanting to design:
      So each of the stems would grow from the edges of the screen, then divide and continue to grow.  the 'flowers' will grow and follow the end of the lines/stems as they grow larger.
      thanks
      nick
        • 1. Re: how best to animate the growing stems of some flowers?
          carl schooff Level 3
          Thanks for providing the image, it really helps when trying to answer these questions.
          Unfortunately the keyframed mask reveal method that you learned about is probably the most beginner-friendly method. But as you have noticed it is very tedious and gets very complicated once you start adding lots of curves as it becomes difficult to maintain a mask that reveals the entire line.
          What you want to do is very possible via actionscript but unfortunately requires: a) a great deal of actionscript knowledge and b) a good bit of math / trigonometry.
          Here is the last step of an 8 part tutorial that I found. It probably won't solve your problem but will help you understand the complexity of something so seemingly simple:
          http://www.reflektions.com/miniml/template_permalink.asp?id=254
          For further research try googling "flash drawing api animating"
