4 Replies Latest reply on Jan 5, 2010 10:11 PM by LaVengeance
    problem in  code
    naval joshi Level 1
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="creationCompleteHandler(event);">
      <mx:Script>
      <![CDATA[
      import flash.events.*;
      import mx.events.FlexEvent;
      [Bindable]
                  private function creationCompleteHandler(event:FlexEvent):void
                      // Listen for the click event on the Button control
                      myButton.addEventListener (MouseEvent.CLICK, handler);
      public function handler(e:MouseEvent):void
      var j:URLLoader=new URLLoader();
      var req:URLRequest=new URLRequest("C:\Users\nikhiljoshi122\Desktop\naval files\flex\xmln\nj.xml");
      j.load(req);
      j.addEventListener(Event.COMPLETE,loaded);
      private function loaded(e:Event):void
      var temp_xml:XML=e.currentTarget.Data;
      trace(temp_xml)
      myButton.label ="loaded";
      </mx:Script>
      <mx:TextArea x="157" y="68" width="175" height="150" id="t1" text="{temp_xml}"/>
      <mx:Label x="157" y="42" text="data file" width="113"/>
          <mx:Button id="myButton" label="Click Me!"  x="167" y="226"/>
      </mx:Application>
      I am a new learner of flex action script.............heres ma code.i m nt getting the xml loaded in the datagrid.....flex builder says at line 10 in creationcomplete handler function it requiresan event name parameter  with [bindable]......
      i m nt gettin...pls help
        • 1. Re: problem in  code
          rgadiparthi Level 2
          seems your xml is not formated properly.
          try to find the problem and correct it or else attach your xml here.
          • 2. Re: problem in  code
            LaVengeance Level 1
            Some issues:
                 -  I don't see a datagrid here, but a TextArea
                 - You can't assign a variable of type XML to a text area, it needs to be of type String
                 - the variable temp_xml needs to be declared at the class level so that it is visible to components outside of the private function in which you are             updating it
                 - It's better to avoid spaces in the URLs that you use, I'm not so sure if it will fail but it's good to avoid spaces in URLs ( change your folder name from  naval files to something like naval_files)
            the code below should work fine :
            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="creationCompleteHandler()">
            <mx:Script>
            <![CDATA[
            [Bindable]
            var temp_xml:String;
            private function creationCompleteHandler():void
            var req:URLRequest=new URLRequest("C:\Users\nikhiljoshi122\Desktop\naval_files\flex\xmln\nj.xml");
            j.load(req);
            temp_xml=e.currentTarget.data as String;
            trace(temp_xml)
            </mx:Script>
                <mx:Button id="myButton" label="Click Me!"  x="167" y="226" />
            </mx:Application>
            Cheers
            • 3. Re: problem in  code
              naval joshi Level 1
              thanxx ....problem solved!!
              • 4. Re: problem in  code
                LaVengeance Level 1
                glad to be of help !
                Good luck
