1 Reply Latest reply on Jan 4, 2010 1:31 PM by MisterIsh
    FLV Cue Points from Soundbooth
    MisterIsh
      I am having a strange issue. I have several audio files that I have opened in Sounbooth and added cue points. I saved the files as FLVs. Upon importing into Flash CS4 with the FLVPlayback component, my cue points are not loading. The component inspector shows "cuePoints: None".  In a test I did before the New Year, the cue points loaded fine. I have no idea what I did differently this time.  Any ideas?  I know I can add the cue points in the FLVPlayback component, but I'd rather be able to do it in Soundbooth.
      Thank you!
        • 1. Re: FLV Cue Points from Soundbooth
          MisterIsh Level 1
          This is an annoying work around, but here's how I got the cue points from Soundbooth to be recognized in Flash:
          1. Opened the original MP3 in Soundbooth
          2. Added my markers/cue points
          3. Saved As ".AVI"
          4. Saved again as ".F4V" (not FLV)
          5. Imported the F4V into the FLVPlayback component
          NOTE: If you add a new cue point to the FLV and try to resave as the same file name, the latest cue point will not import into Flash. I had to do yet another save as and pick a new file name.
          Going to try to eliminate the AVI step, but note hopeful.
          Hope this helps others.
