3 Replies Latest reply on Jan 5, 2010 5:10 PM by jerryhamby
    ImageElement Event Inconsistencies
    jerryhamby
      This is a followup from a post I made 2 weeks ago titled:
      "perfect time to capture image size"     Filed bug: FM-301
      All I'm trying to do is find the ONE event that will give me a consistent
      width and height for the current imageElement, so I can run some resizing code.
      I'm testing against 3 events, but under one condition or another, all of them fail:
      1- MediaPlayerStateChangeEvent.MEDIA_PLAYER_STATE_CHANGE
      2- LoadEvent.LOAD_STATE_CHANGE
      3- ViewEvent.DIMENSION_CHANGE
      My test is built using MediaPlayer placed inside a Sprite.
      I'm NOT using MediaPlayerSprite nor MediaPlayerElement .
      Test 1: (one image)
      var vImageElement=new ImageElement(new ImageLoader  ,new URLResource(new URL("./images/image4.jpg")));
      pPlayer.element=vImageElement;
      Test 2: (2 images using TemporalProxyElement)
      pImageSerialElement.addChild(new TemporalProxyElement(3,new ImageElement(new ImageLoader  ,new URLResource(new URL("./images/image4.jpg")))));
      pImageSerialElement.addChild(new TemporalProxyElement(3,new ImageElement(new ImageLoader  ,new URLResource(new URL("./images/image2.png")))));
      pPlayer.element=pImageSerialElement;
      ======  MEDIA_PLAYER_STATE_CHANGE  ======
      Test 1: this works fine
      Test 2: evt.currentTarget.width =  0     and   evt.currentTarget.height =  0
      ======  LOAD_STATE_CHANGE  evt.state = ready  ======
      ======  DIMENSION_CHANGE ======
      Test 1: this event does not fire
      Test 2: this works with the except that it fires twice  (Bug Filed:  FM-300)
      My conclusion is that either:
      1- I have to use 2 different set of events if I'm displaying one image as opposed
      to displaying a slide show with multiple images. This is not my preferred choice.
      2- The OSMF API  has a bug.
      The code Ryan supplied in "perfect time to capture image size" was for a MediaPlayerSprite.
      I haven't had time to test MediaPlayerSprite, but shouldn't both methods be consistent?
      Sorry to keep beating this thing to death
        • 1. Re: ImageElement Event Inconsistencies
          jerryhamby Level 1
          I just added one more event for testing:
          ======  VIEWABLE_CHANGE  (MediaPlayerCapabilityChangeEvent) ======
          Test 1: works fine
          • 2. Re: ImageElement Event Inconsistencies
            bringrags Level 4
            These are bugs, you should get the same event in both cases.  The first (DIMENSION_CHANGE, Test 1, no event fires) is now fixed in the public trunk.  The second (DIMENSION_CHANGE, Test 2, multiple events fire) is a layout bug, can you file it?  Please reference this thread.
            Additional detail:  The second bug is a result of LayoutContextSprite.updateIntrinsicDimensions updating the height and the width separately.  Ideally this would be done atomically, so that a single event would be dispatched.
            • 3. Re: ImageElement Event Inconsistencies
              jerryhamby Level 1
              From your reply it looks like, once the bugs are fixed that DIMENSION_CHANGE will be the perfect place to capture the width and height.
              Thanks, I think I can let this one go until Sprint 9.
              I have already filed a bug on the multiple events firing, a couple of weeks ago:
              Bug:  FM-300
              Title:  "DimensionChangeEvent firing twice (TemporalProxyElement)"
              I just posted your forum answer, as a comment to the bug base.
