Hi again Malcolm
Here it is in a nutshell. I created a rollover caption for
that area. Position the caption exactly where you want it. Then
preview it in any way that works. Either within Captivate or in the
browser. While previewing, mouse over the area so you see the
dialog and the caption together. Then screen capture the caption as
it is displayed on top of the dialog.
Now comes the fun part! You edit the screen capture to erase
what you don't need to see. This would include the dialog. However,
you do want to keep part of it visible in order to create the red
outline. Once you get the red outline, you can then erase all the
remaining bits. What you end up with is an image that contains only
the text caption and the red outline.
Now flood fill the background with a color that isn't used
elsewhere. I tend to use hot pink a lot. You do this so all that
area becomes transparent.
Now save the image and insert it as a rollover image! You
will probably find that working this way will force you to
initially grab a sizing handle on the image and scale it way tiny
just so you can position and size the rollover area. But the neat
part is that you can just double click the image later to get at
the properties. Then click the "Reset to original size" button to
"re-inflate" it back to what it should be.
With Captivate 2 this whole process should be much easier
because once you get the rollover area and rollover image placed,
you can then hide it by clicking the right spot in the timeline.
Hope this helped... Rick
