4 Replies Latest reply on Jan 9, 2010 8:25 PM by John Hall
    State change with custom event
    John Hall Level 4
      I have an oddball thing going on. I have a component for which can change the state without issue with a buttonclick within the component. However, when I create a custom event to change the state based on something else happening, it won't change.
      In it's simplest form, here are the two instances
      This is the script within the component that works fine:
                  public function displayState():void{
                      currentState = "display";
                      trace(this.currentState);
                traces: display
                shows: display state
      However, this script, which receives a custom event and parameter, displays the trace properly saying that it has changed states but it doesn't refresh the screen to reflect that:
                  public function changeState(value:String):void{
                      currentState = value;
                traces: display
                shows: remains on edit state
      To add to the mix, even if I hard wire the state change as a test that is triggered by the custom event, once again it traces properly saying that it has changed state but no difference on the screen.
                traces: display
      Am I missing something obvious?
      I've tried the beta 2 plus 2 different nightly builds including the Jan 5 build.
