4 Replies Latest reply on Jan 5, 2010 9:31 AM by Matt Le Fevre
    How do I Pass Variables to a POPUP (titleWindow).
    Christian A. Smith
      I was originally trying to create a titleWindow and set certain properties based on data in the calling program.  However, I could only set the direct properties (ie.  'title').  When I try to set the HBox properties (hbNotEmployted) in the popup I recieve an abend of null reference.  I'm assuming I can't access the mxml because the window has not been created.  Below is the current code I was trying to use.
      Is there a way for me to Pass an array or string value to the popup.
      if (dataField.toString() == "buttonIcon")
           allocationsPopUp =
      new AllocationsPopUp();
           allocationsPopUp.title = data.Name;
      if ( data.Error == "1")
           allocationsPopUp.hbNotEmployed.visible =
      false;
           allocationsPopUp.hbNotEmployed.includeInLayout = false;
           allocationsPopUp.show(
      this as DisplayObject, true, true );
