0 Replies Latest reply on Jan 5, 2010 9:33 AM by HansMuller
    [svn:fx-trunk] 13277: Changed the RichText. text set method to short-circuit if _text == value ( as in TextBase and RichEditableText) and if the value of _text was most recently set by explicitly setting the text property .
    HansMuller Level 1
      Revision: 13277
      Revision: 13277
      Author:   hmuller@adobe.com
      Date:     2010-01-05 09:33:32 -0800 (Tue, 05 Jan 2010)
      Log Message:
      Changed the RichText.text set method to short-circuit if _text == value (as in TextBase and RichEditableText) and if the value of _text was most recently set by explicitly setting the text property.
      QE notes:
      Doc notes:
      Bugs: sdk-24838
      Reviewer: Carol
      Tests run:
      Is noteworthy for integration: no
      Ticket Links:
          http://bugs.adobe.com/jira/browse/sdk-24838
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/RichText.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Scroller.as
