0 Replies Latest reply on Jan 5, 2010 9:57 AM by Carol L. Frampton
    [svn:fx-trunk] 13279: TLF V1.0 build 584.
    Carol L. Frampton Level 2
      Revision: 13279
      Revision: 13279
      Author:   cframpto@adobe.com
      Date:     2010-01-05 09:57:39 -0800 (Tue, 05 Jan 2010)
      Log Message:
      TLF V1.0 build 584.
      Add TLF samples to samples\textLayout.
      Since textLayout.zip now includes the doc files we will use those in the fat swc rather than build our own.
      Had to run unix2dos on bundles/en_US/docs/ASDoc_Config.xml and overviews.xml so svn would allow them to be added.  We exclude these from our swc so it doesn't really matter if we have these files but integration is easier if there are fewer special cases to handle.
      QE notes:
      Doc notes: sample apps may be of interest
      Bugs:
      Reviewer: Jim reviewed build changes
      Tests run: TextArea, TextInput, ComboBox, RichText, Label
      Is noteworthy for integration:
      Modified Paths:
          flex/sdk/trunk/build.xml
          flex/sdk/trunk/frameworks/air-config.xml
          flex/sdk/trunk/frameworks/build.xml
          flex/sdk/trunk/frameworks/flex-config.xml
          flex/sdk/trunk/frameworks/libs/textLayout.swc
          flex/sdk/trunk/frameworks/projects/textLayout/HowToUpgradeTLF.txt
          flex/sdk/trunk/frameworks/projects/textLayout/ReleaseNotes.txt
          flex/sdk/trunk/frameworks/projects/textLayout/build.xml
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/BuildInfo.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/BaseCompose.a s
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/FlowComposerB ase.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/FlowDamageTyp e.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/StandardFlowC omposer.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/TextFlowLine. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/container/ContainerCo ntroller.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/container/ISandboxSup port.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/container/TextContain erManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/conversion/ITextExpor ter.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/conversion/ITextImpor ter.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/conversion/PlainTextE xporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/conversion/PlainTextI mporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/conversion/TextLayout Importer.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/debug/Debugging.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/EditManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/IEditManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/IMEClient.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/ParaEdit.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/SelectionManager .as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/BreakElement .as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/Configuratio n.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/FlowElement. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/FlowGroupEle ment.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/GlobalSettin gs.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/SpanElement. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/factory/StringTextLin eFactory.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/factory/TextFlowTextL ineFactory.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/factory/TextLineFacto ryBase.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/IMEStatus.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/ITabStopForma t.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/ITextLayoutFo rmat.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/TabStopFormat .as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/TabStopFormat Inc.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/TextLayoutFor mat.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/TextLayoutFor matInc.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/TextLayoutFor matValueHolder.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/operations/ApplyForma tOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/operations/ApplyLinkO peration.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/operations/FlowElemen tOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/tlf.properties
      Added Paths:
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/ASDoc_Config.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flash.text.ime.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.compos e.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.contai ner.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.conver sion.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.edit.x ml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.elemen ts.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.events .xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.factor y.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.format s.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.operat ions.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.utils. xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.undo.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/overviews.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/packages.dita
          flex/sdk/trunk/samples/textLayout/
          flex/sdk/trunk/samples/textLayout/actionscript/
          flex/sdk/trunk/samples/textLayout/actionscript/FTE/
          flex/sdk/trunk/samples/textLayout/actionscript/FTE/.actionScriptProperties
          flex/sdk/trunk/samples/textLayout/actionscript/FTE/.project
          flex/sdk/trunk/samples/textLayout/actionscript/FTE/FTEHelloWorld.as
          flex/sdk/trunk/samples/textLayout/actionscript/FTE/FTEParagraph.as
          flex/sdk/trunk/samples/textLayout/actionscript/Logo.jpg
          flex/sdk/trunk/samples/textLayout/actionscript/Pagination/
          flex/sdk/trunk/samples/textLayout/actionscript/Pagination/.actionScriptProperties
          flex/sdk/trunk/samples/textLayout/actionscript/Pagination/.project
          flex/sdk/trunk/samples/textLayout/actionscript/Pagination/Alice.as
          flex/sdk/trunk/samples/textLayout/actionscript/Pagination/Pagination.as
          flex/sdk/trunk/samples/textLayout/actionscript/Pagination/PaginationWidget.as
          flex/sdk/trunk/samples/textLayout/actionscript/ReadmeAS.html
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/.actionScriptProperties
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/.project
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/ContextMenuText.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/CustomImportMarkup.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/CustomLinkEventHandler.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/EditText.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/ExplicitFormField.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/HelloWorld.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/ImportMarkup.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/InlineGraphic.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/LinkedContainers.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/MultipleColumns.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/MultipleContainerColumns.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/ParagraphBorder.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/ParagraphBounds.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/SelectText.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/StaticHelloWorld.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/StaticTextFlow.as
          flex/sdk/trunk/samples/textLayout/flex/
          flex/sdk/trunk/samples/textLayout/flex/Logo.jpg
          flex/sdk/trunk/samples/textLayout/flex/ReadmeFlex.html
          flex/sdk/trunk/samples/textLayout/flex/SimpleEditor/
          flex/sdk/trunk/samples/textLayout/flex/SimpleEditor/.actionScriptProperties
          flex/sdk/trunk/samples/textLayout/flex/SimpleEditor/.flexProperties
          flex/sdk/trunk/samples/textLayout/flex/SimpleEditor/.project
          flex/sdk/trunk/samples/textLayout/flex/SimpleEditor/SimpleText.xml
          flex/sdk/trunk/samples/textLayout/flex/SimpleEditor/src/
          flex/sdk/trunk/samples/textLayout/flex/SimpleEditor/src/SimpleEditor.mxml
          flex/sdk/trunk/samples/textLayout/flex/SimpleEditor/src/SimpleEditorPanel.mxml
          flex/sdk/trunk/samples/textLayout/flex/SimpleEditorWithCSS/
          flex/sdk/trunk/samples/textLayout/flex/SimpleEditorWithCSS/.actionScriptProperties
          flex/sdk/trunk/samples/textLayout/flex/SimpleEditorWithCSS/.flexProperties
          flex/sdk/trunk/samples/textLayout/flex/SimpleEditorWithCSS/.project
          flex/sdk/trunk/samples/textLayout/flex/SimpleEditorWithCSS/SimpleText.xml
          flex/sdk/trunk/samples/textLayout/flex/SimpleEditorWithCSS/src/
          flex/sdk/trunk/samples/textLayout/flex/SimpleEditorWithCSS/src/CSSFormatResolver.as
          flex/sdk/trunk/samples/textLayout/flex/SimpleEditorWithCSS/src/SimpleCSS.css
          flex/sdk/trunk/samples/textLayout/flex/SimpleEditorWithCSS/src/SimpleEditorPanel.mxml
          flex/sdk/trunk/samples/textLayout/flex/SimpleEditorWithCSS/src/SimpleEditorWithCSS.mxml
          flex/sdk/trunk/samples/textLayout/flex/TextLayoutEditor/
          flex/sdk/trunk/samples/textLayout/flex/TextLayoutEditor/.actionScriptProperties
          flex/sdk/trunk/samples/textLayout/flex/TextLayoutEditor/.flexProperties
          flex/sdk/trunk/samples/textLayout/flex/TextLayoutEditor/.project
          flex/sdk/trunk/samples/textLayout/flex/TextLayoutEditor/src/
          flex/sdk/trunk/samples/textLayout/flex/TextLayoutEditor/src/TextLayoutEditor.mxml
          flex/sdk/trunk/samples/textLayout/flex/TextLayoutEditor/src/TextLayoutEditorCanvas.mxml
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/.actionScriptProperties
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/.flexLibProperties
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/.project
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/build-editBar.xml
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/EditBarClasses.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/FeatureSetChang eEvent.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/FileEvent.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/FileIOHelper.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/FileServices.mx ml
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/GraphicBar.mxml
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/GraphicChangeEv ent.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/LinkBar.mxml
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/LinkChangeEvent .as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/SingleContainer View.mxml
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/SpriteWithIME.a s
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/StatusPopup.mxm l
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/StyleChangeEven t.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/%icon_tc y.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/BreakOpp ortunityType.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/EmbedDel eteIcon.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/EmbedDel eteIconDisabled.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/P_TextAl ignBottom_Sm_N.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/P_TextAl ignJustify_Sm_N.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/P_TextAl ignMiddle_Sm_N.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/P_TextAl ignTop_Sm_N.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/P_TextBa selineShift_Md_N.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/P_TextBo ttomOffset_Md_N.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/P_TextFi rstLineIndent_Md_N.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/P_TextLe ftIndent_Md_N.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/P_TextLe ftOffset_Md_N.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/P_TextRi ghtIndent_Md_N.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/P_TextRi ghtOffset_Md_N.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/P_TextSm allCaps_Md_N.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/P_TextSp aceAfter_Md_N.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/P_TextSp aceBefore_Md_N.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/P_TextTo pOffset_Md_N.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/TextAuto LeadingPercent.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/digitCas e.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/digitWid th.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/elementB aseline.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/icon_ali gn_all_but_last.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/icon_ali gn_center.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/icon_ali gn_end.PNG
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/icon_ali gn_justify.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/icon_ali gn_left.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/icon_ali gn_right.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/icon_ali gn_start.PNG
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/icon_bul let.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/icon_sty le_bold.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/icon_sty le_italic.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/icon_sty le_strikethrough.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/icon_sty le_underline.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/icon_tcy .png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/ligature s.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_editBar/src/textEditBar/assets/lineBase line.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/.actionScriptProperties
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/.flexLibProperties
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/.project
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/BxfClasses.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/assets/
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/assets/finger_scrub_cur.p ng
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/assets/icon_inspector_pop up_arrows.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/controls/
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/controls/BxPopupMenu.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/controls/ConflictOverlay. as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/controls/HUDComboPopupCon trol.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/controls/HUDImagePopupCon trol.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/controls/HotText.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/controls/HotTextEvent.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/controls/HotTextNumber.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/controls/IMouseCapture.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/inspectors/
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/inspectors/CheckboxProper tyEditor.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/inspectors/ColorPropertyE ditor.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/inspectors/ComboBoxProper tyEditor.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/inspectors/DynamicPropert yEditorBase.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/inspectors/FontPropertyEd itor.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/inspectors/HotNumericProp ertyEditor.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/inspectors/HotNumericWith UnitsEditor.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/inspectors/HotTextInput.a s
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/inspectors/IHUDLayoutElem ent.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/inspectors/IPropertiesEdi tor.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/inspectors/IPropertyEdito r.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/inspectors/MultiIconButto nSelector.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/inspectors/PictureButtonP ropertyEditor.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/inspectors/PropertyEditEv ent.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/inspectors/PropertyEditor Base.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/inspectors/SimpleCheckbox PropertyEditor.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/inspectors/StringButtonPr opertyEditor.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/inspectors/StringProperty Editor.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/inspectors/ToggleButtonPr opertyEditor.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/inspectors/ValueChangeNot ifier.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/toolkit/
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/toolkit/ITrackerInterface .as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/toolkit/Tracker.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/utils/
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/utils/EffectiveStage.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/bxf/ui/utils/LocalString.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/UiClasses.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/MultiPanel. as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/MultiPanelH eaderSkin.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/PanelWithEd geBars.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/VellumGUISt yles.css
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/assets/
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/assets/%scr oll_arrow_down_over.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/assets/%scr oll_arrow_up_over.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/assets/Font s.swf
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/assets/comb o_drop_down_arrow.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/assets/head er_close_icon.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/assets/head er_open_icon.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/assets/scro ll_arrow_down.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/assets/scro ll_arrow_down_over.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/assets/scro ll_arrow_up.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/assets/scro ll_arrow_up_over.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ AdvancedTextPropertyEditor.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ AntiAliasPropertyEditor.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ CharacterPropertyEditor.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ DynamicTextPropertyEditor.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ LinkPropertyEditor.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ ParagraphPropertyEditor.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ SelectionUpdateEvent.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ TabPropertyEditor.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ TextContainerPropertyEditor.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ TextFlowPropertyEditor.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ TextInspectorController.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ assets/
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ assets/align_center_icon.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ assets/align_end_icon.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ assets/align_justify_icon.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ assets/align_last_center_icon.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ assets/align_last_left_icon.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ assets/align_last_right_icon.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ assets/align_left_icon.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ assets/align_right_icon.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ assets/align_start_icon.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ assets/bold_icon.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ assets/cont_align_bottom_icon.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ assets/cont_align_justify_icon.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ assets/cont_align_middle_icon.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ assets/cont_align_top_icon.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ assets/italic_icon.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ assets/strikethrough_icon.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ assets/subscript_icon.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ assets/superscript_icon.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ assets/tcy_icon.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/inspectors/ assets/underline_icon.png
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/rulers/
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/rulers/Para graphPropertyMarker.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/rulers/Para graphPropertyMarkerSkin.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/rulers/Rule rBar.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/rulers/Rule rDragTracker.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/rulers/Rule rMarker.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/rulers/TabM arker.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/rulers/TabM arkerSkin.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/styles/
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/styles/Popu pMenuSkin.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/styles/Scro llbarDownArrowUpSkin.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/styles/Scro llbarThumbOverSkin.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/styles/Scro llbarThumbUpSkin.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/styles/Scro llbarTrackSkin.as
          flex/sdk/trunk/samples/textLayout/flex/textLayout_ui/src/flashx/textLayout/ui/styles/Scro llbarUpArrowUpSkin.as
      Property Changed:
          flex/sdk/trunk/frameworks/locale/en_US/
