1 Reply Latest reply on Jan 12, 2010 6:01 PM by BAZZ C
    Installing CFBuilder Beta3 as Plugin - Problem
    Rora
      Okay, so I'll admit to doing it completely wrong the first time.
      I think I probably did just about eveything you weren't supposed to do.
      1.  I had eclipse and the cfbuilder beta2 perspective open
      2.  I uninstalled from the windows add/remove programs (which incidently didn't uninstall a bunch of stuff because it was open)
      3.  At this point I ended up just going into the eclipse folder and deleteing everying from the plug-in directory marked "com.adobe..."
      At this point it let me install, and completed without screaming at me.
      So now, I open eclipse, and try to open the cf perspective and its not there.
      So NOW I read the directions, and I try starting this from scratch
      1.  Uninstall beta 3
      2.  close and reopen eclipse with the -clean
      3.  threw in a reboot here just in case
      4.  Install beta 3
      5.  Open eclipse with the -clean
      So, I go to open the perspective, still not there.
      However I go to the Eclipse - Help - About Eclipse Platform and I see the CF logo, I go to the installed plug-ins and its listed, I go to the Window - Preferences and I can configure it.  I just can't get it into the menu to open it.
      Incidently - Eclipse Ganyamede - 3.4.2
      Anyone have any ideas?
        • 1. Re: Installing CFBuilder Beta3 as Plugin - Problem
          BAZZ C
          Go to the plugins window and view the properties for the plugin, and then have a look under 'Status'
          It might list out the things that are wrong with it.
          I have a similar issue where it doesn't work properly after installing it as a plugin, the issues mine shows under 'Status' is:
          Plug-in "com.adobe.html.help" version "0.0.0" referenced by this feature is missing.
          Plug-in "org.derby.driver" version "1.5.0.25222" referenced by this feature is missing.
          Plug-in "org.eclipse.atf.mozilla.ide.core" version "0.2.1.v200703161053" referenced by this feature is missing.
          Plug-in "com.extjs.ext.3.0" version "1.0.0.001" referenced by this feature is missing.
          I haven't been able to find where to get those plugins either yet.
