0 Replies Latest reply on Jan 5, 2010 3:22 PM by Peter Farland
    [svn:fx-trunk] 13288: Changing the workaround for custom whitespace preservation in spark components in order to cater for fixes to SDK-24699 and SDK-24611 .
    Peter Farland Level 3
      Revision: 13288
      Revision: 13288
      Author:   pfarland@adobe.com
      Date:     2010-01-05 15:21:57 -0800 (Tue, 05 Jan 2010)
      Log Message:
      Changing the workaround for custom whitespace preservation in spark components in order to cater for fixes to SDK-24699 and SDK-24611.
      We now preserve whitespace for all of the spark "text" tags at compile time (but not only-whitespace content if an alternate text attribute was specified).
      QE notes: Please ensure that whitespace preservation continues to work, including for the scenarios mentioned in previous issues SDK-22601, SDK-23160, SDK-23972.
      Doc notes: N/A
      Bugs:
      SDK-24699 - Binding does not work with Spark TextInput "text" property
      SDK-24611 - MXML compiler should preserve whitespace in FlowElement tags (such as
      Reviewer: Paul
      Tests run: checkintests, mustella RichText, List, TextArea (the 2 baseline position failures existed prior to these changes)
      Is noteworthy for integration: Yes
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24699
          http://bugs.adobe.com/jira/browse/SDK-24611
          http://bugs.adobe.com/jira/browse/SDK-22601
          http://bugs.adobe.com/jira/browse/SDK-23160
          http://bugs.adobe.com/jira/browse/SDK-23972
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/MxmlScanner.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/Node.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.java
