2 Replies Latest reply on Jan 6, 2010 7:37 AM by gvwalsh
    Turning off frame blending in Adobe Media Encoder
    gvwalsh
      Is there a way to turn off frame blending in Adobe Media Encoder?  I have a bunch of
      Flip Mino HD footage (1280x720p) which I wish to convert to P2 720p format so that
      I can more easily mix and match it in the Premiere timeline with actual P2 footage
      shot on an HVX200.
      I successfully used Media Encoder to perform this task but there is one problem.  The
      Flip footage is 30fps and P2 720p is 29.97fps.  So Media Encoder uses frame blending.
      The frame blending sometimes creates obnoxious artifacts so I would like to turn it
      off but there seems to be no way to do this (or alternatively "conform" the 30fps input
      to 29.97fps so that no blending is nescessary).
      After Effects CS4 would seem like an alternative since it has nice batch composition
      creation and rendering features but it cannot render to the P2 format - it appears to
      have a older version of Media Encoder embedded within it - predating P2 support.
      I would like a solution that is easily "batchable" as I have several hunderd Flip Mino HD
      clips that need to be processed.
      You might also ask, why not just import the Flip clips unchanged into Premiere CS4
      and mix them with the P2 clips?....I have tried this and it seems to drive Premiere crazy
      introducing various crashes and other strange behaviors.  The pre conversion to P2
      route seems to work fine.  I just want to get rid of the frame blending.
