0 Replies Latest reply on Jan 5, 2010 5:31 PM by Jason Szeto
    [svn:fx-trunk] 13296: Change event split into change and valueCommit for list based components
    Jason Szeto Level 3
      Revision: 13296
      Revision: 13296
      Author:   jszeto@adobe.com
      Date:     2010-01-05 17:31:52 -0800 (Tue, 05 Jan 2010)
      Log Message:
      http://bugs.adobe.com/jira/browse/SDK-24803 - When selectedItem/selectedIndex is set programatically, list should dispatch a valueCommit event, not a change event
      Refactored selection properties into helper functions which parameterize dispatching changing/change events. Changed all internal setting of the selection properties to use these helper functions.
      Updated binding metadata for selection properties.
      QE notes: Update tests
      Doc notes: Docs should mention valueCommit versus change/changing
      Bugs: SDK-24803
      Reviewer: Ryan
      Tests run: checkintests, ButtonBar, List, ComboBox, DropDownList
      Is noteworthy for integration: No
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/ComboBox.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/List.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/ButtonBarBas e.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/DropDownList Base.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/ListBase.as
