0 Replies Latest reply on Jan 5, 2010 7:07 PM by jmurphy67
    [svn:fx-trunk] 13299: fix the _rb swc so that it updates properly when changes happen - update=" true" so that it will compile correctly when using locales
    jmurphy67 Level 1
      Revision: 13299
      Revision: 13299
      Author:   jimurphy@adobe.com
      Date:     2010-01-05 19:07:45 -0800 (Tue, 05 Jan 2010)
      Log Message:
      fix the _rb swc so that it updates properly when changes happen - update="true" so that it will compile correctly when using locales
      QE notes: ensure it contains a catalog.xml file, a swf, and a locale directory with properties file
      Doc notes:
      Bugs: https://bugs.adobe.com/jira/browse/SDK-24802
      Reviewer: pete
      Tests run:
      Is noteworthy for integration: no
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24802
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/build.xml
