4 Replies Latest reply on Jan 6, 2010 2:41 AM by seRajan
    Flex automation - need to capture the mousemove
    seRajan
      hi All,
           I am creating Whiteboard application. I want to test my application through automation, but i can't capture the mousemove event.
      Inside the Whiteboard i have drawing fucntionality, this functionality require the mousedown, mousemove and mouseup events. I need to capture these events.
      Please help me.
      - Rajan
        • 1. Re: Flex automation - need to capture the mousemove
          Claudino Bur Level 2
          Hello,
          Try Application.application.stage.addListener(MouseEvent.MOUSE_DOWN,mousedown_handler) which mousedown_handler is a function accepting a MouseEvent parameter.
          Look also at this example http://www.java2s.com/Code/Flash-Flex-ActionScript/Development/Addmouseupanddownlistener.h tm
          Claude Bur.
          • 2. Re: Flex automation - need to capture the mousemove
            seRajan Level 1
            Thank you for the replay.
            My requirement for Flex Automation.
            I added mouse listeners, but those events wants to record into automation.
            Please check this : http://www.adobe.com/devnet/flex/samples/custom_automated/
            currrently this sample file only capture the mouseclick event. I need to record other mouse listener also.
            - Rajan
            • 3. Re: Flex automation - need to capture the mousemove
              Hello,
              Download customagent_src.zip and there you will find AutomationGenericEnv.xml. I see there
                   <Event Name="MouseMove" >
                              <Implementation Class="flash.events::MouseEvent" Type="mouseMove"/>
                   <Event Name="Click" >
                               <Implementation Class="flash.events::MouseEvent" Type="click"/>
              As you can see only those 2 events click and mouseMove are registered for listening. Add your listeners there for example mouseUp, mouseDown etc.
              Claude Bur.
              • 4. Re: Flex automation - need to capture the mousemove
                seRajan Level 1
                I tryed that method.
                This is my sample file:
                <mx:Application
                xmlns:mx="http://www.adobe.com/2006/mxml"
                applicationComplete="init();"
                <mx:Script>
                <![CDATA[
                import mx.automation.Automation;
                import mx.automation.IAutomationManager;
                private function init():void
                bindDraw.addEventListener(MouseEvent.MOUSE_DOWN, _MouseDownHandler,
                false, 0, true);
                private function _MouseDownHandler(evt:MouseEvent):void
                this.systemManager.addEventListener(MouseEvent.MOUSE_UP, _MouseUpHandler, false, 0, true);
                bindDraw.addEventListener(MouseEvent.MOUSE_MOVE, _MouseMoveHanlder,
                false, 0, true);
                bindDraw.graphics.lineStyle(3, 0, 1);
                bindDraw.graphics.moveTo(evt.localX, evt.localY);
                private function _MouseMoveHanlder(evt:MouseEvent):void
                bindDraw.graphics.lineTo(evt.localX, evt.localY);
                private function _MouseUpHandler(evt:MouseEvent):void
                bindDraw.graphics.clear();
                this.systemManager.removeEventListener(MouseEvent.MOUSE_UP, _MouseUpHandler, false);
                bindDraw.removeEventListener(MouseEvent.MOUSE_MOVE, _MouseMoveHanlder,
                false);
                private var _count:Number = 0;
                private function clickHandler(evt:MouseEvent):void
                evt.currentTarget.label=
                "clicked "+(++_count);
                </mx:Script>
                <mx:Button id="b1" label="click me" click="clickHandler(event)"/>
                <mx:Canvas showInAutomationHierarchy="true" id="bindDraw" width="100%" height="100%" />
                <mx:Canvas id="fff" width="100" height="100" backgroundColor="34233"/>
                </mx:Application>
