0 Replies Latest reply on Jan 6, 2010 7:15 AM by frostbytefalls
    Acro Preflight "Destination profile not recommended" ?
    frostbytefalls Level 1
      But checking Ghent (www.gwg.org) says I am using the recommended profile!
      The printing environment is open web on newsprint.
      The file was exported out of InDesign as PDF/X-1a (Destination SNAP 2007) and Output Intent SNAP 2007.
      Here you will see a chart that says that's the right profie: http://gwg.org/37.277.0.0.1.0.phtml
      The full warning message from Acrobat's preflight tool:
      "Desntination profile is not recommended for Web Offset (cold set)
      The Ghent Workgroup recommends certain ICC profiles for use as a destination profile in the PDF/X output intent when exchanging PDF/X files according to the Ghent specifications. See www.gwg.org."
      If I run the fix-up from the Preflight tool it changes the output intent to ISO/DIS 12647... somthing.
      What the heck?
      Thanks for any input on this.
